FlyPT Mover 3.5.3
  1. pmvcda
    15,641Coins
    Please, try @GWiz solution.
    I already have F1 23 and I will add it with F1 23 telemetry.
  2. sallerding
    sallerding Member
    Perth, Western Australia
    344Coins
    Hey @pmvcda . I see you have got quite a list of requests going. I don’t want to add to those, but one point you were potentially exploring support for witmotion in flypt for motion compensation. I’m not seeking to add to the list of requests, but just wanted to know whether that was something you were still pursuing or whether you decided it wasn’t something that you would look to implement? Thx
  3. pmvcda
    15,641Coins
    I already have it. There's bug somewhere causing problems when changing speeds, rate and baud rate.
    Also meed to check what is the setup used in other apps to make it match..
  4. sallerding
    sallerding Member
    344Coins
    Wow! That would be a great addition if the bugs are ironed out. Thx for the reply
  5. stachu
    stachu New Member
    22Coins
    Geiz, thanks for your help but sadly this does not work in f1 23. In all other Sims it’s no problem. But ok, for me it’s fine to wait for the next update with the sources, really no pressure from my side. I’m very thankfull, that the software is for free and so powerfull!
    Btw. Last question: will there also be a source for sim tools 3.0?
  6. Marco Annunziata
    919Coins
    Hello everyone,
    I remember something about the possibility of recording a video synchronized with the telemetry that runs on the mover, like a specific source, am I remembering wrong?
    Thank yall
  7. Yeti86
    Yeti86 New Member
    132Coins
    Hello!
    I've only been able to run V. 3.5.1. v2 and v3 give me a .Net Framework error:
    System.Net.WebException: Unable to connect to the remote server ---> System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it 85.247.75.102:80
    at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress)
    at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception)
    --- End of inner exception stack trace ---
    at System.Net.WebClient.UploadValues(Uri address, String method, NameValueCollection data)
    at Mover.Setups.SaveSharedSetup.Exists()
    at System.Windows.Forms.Control.OnVisibleChanged(EventArgs e)
    at System.Windows.Forms.Form.OnVisibleChanged(EventArgs e)
    at System.Windows.Forms.Control.WmShowWindow(Message& m)
    at System.Windows.Forms.Form.WmShowWindow(Message& m)
    at Mover.BaseForm.WndProc(Message& m)
    I'm using OpenComposite as runtime, but also with SteamVR active it crushes.
    But what baffles me is that he tries to connect outside to 85.247.75.102:80 that is refused?
    Any fix to this issue?
    Thank you :)
  8. sallerding
    sallerding Member
    344Coins
    Hi. Is there anyway of accessing online profiles anymore? I just end up with error message saying can’t access.
  9. pmvcda
    15,641Coins
    I will look at the problem. It's related to the online profiles.
    @sallerding , Looking at it. I will have the server working again.
  10. kparkin
    kparkin Member
    United Kingdom
    236Coins
    4DOF
    The net error is now gone, but so have the profile shares
  11. sallerding
    sallerding Member
    344Coins
    Yes flypt is aware
  12. pmvcda
    15,641Coins
    Yes, solved the problem on the server, but I think I have lost the data. I'm trying to recover the file, it's nowhere to be found, runing some recovery software, but that's 20TB...
    It happened because of some updates on the server and the database software.
    Let's hope I solve it.
    The scripts need some changes to work, so for now adding setups is not working well.
  13. kparkin
    kparkin Member
    United Kingdom
    236Coins
    4DOF
    No problem, thanks for all that you do for the community.
  14. Yeti86
    Yeti86 New Member
    132Coins
    yes, like kparkin said, thank you very much for your work, it looks very good and i think it should be understood that a service like you provide comes without warranty. so backup is primarily the users task :)
    i got a question maybe someone can help me with tho;
    i made a diy rig like the DOF H3, but of course, the geometry is different.
    the 3DOF rig has a different placement tho, so it's no use? and the DOF H3 Profile does not allow me to edit the distances of the geometry.
    maybe there is a tutorial or something that shows the config on actual rig maybe? can't seam to find too much other than how to bring the data in and so.
    thanks
  15. Avee
    Avee Virtual Pilot
    1,167Coins
  16. pooh
    pooh Member
    584Coins
    no worries, i will upload my profiles. it still returns some errors like it can't upload profile (while it actually uploaded my msfs2020 profile) and then there are some error saying i cant upload certain profile as it already exists (even though it is not listed - but it was uploaded like a year ago)
  17. pmvcda
    15,641Coins
    I'm aware of the errors, sorry for the problems and thank's for sharing the profiles again. :thumbs
  18. pooh
    pooh Member
    584Coins
    Pedro, one thing i wated to remind as it is an old bug but there was no newer version of Mover since - if you have virtual tracker, then if you launch Mover through profile the VT is not connected even though it has checked autoconnect - you need to open Mover and click on VT for it to connect - would be great if that could be fixed :)
  19. khairul nizam
    khairul nizam dadima
    Retails
    Malaysia
    71Coins
    2DOF, DC motor
    Dear @pmvcda, sorry for bothering again. It's not my intention to push and it is far away for me to be asking when. But if I could ask, is there any chance you could release an upgraded version of the current one(3.5.3) so that I would be able to use GT Sport/7 as the source? I knew that you've been working with ver 4.00 with a lot of new features, but as for the moment, I am okay with the 3.5.3. I need to test my diy motion rig and since this is the only game I have at the moment to test. It's also no problem if you can send me the beta version or minor upgraded version of the latest stable with the GT Sport/7 source in there.
    I've been trying to use custom udp from nenkai's version, send udp from simhub, and even using sim racing studio (custom hook) as sources- all without success. I'm able to receive data, however I didn't understand and it is very much unstable(numbers is moving from +ve to - ve) out of nowhere.
    Hopefully I'm not stressing you with my request.
    Thanks and best regards.
  20. Avee
    Avee Virtual Pilot
    1,167Coins
    I thnk Pedro has lost parts of the original code for the released versions, and has started doing a lot from scratch. It will be an update of 3.5, 4.0 was planned to be a node-red like software. So he is busy releasing an update to the existing platform.
