2DOF Steel frame 24v motors
Discussion in 'DIY Motion Simulator Projects' started by Employee4Life, Dec 9, 2023.
  1. Employee4Life
    Employee4Life New Member
    80Coins
    Hello all. First time poster here. Been a member quite some time and learned a lot on this forum. Thanks too all the people who contribute with codes, parts list and other usefull info. Because of this i got the motivation to try building a motion rig.
    I have been collecting parts for around 9 months now :grin yes, i try buy things cheap, but its mostly due to exspensive shipping fees.
    I welded a frame together with 40x40 steel tube. With a scrap ballbearing mount i found. For now i go for 2dof, but initial thought was 3dof. I still have a motor in spare.
    I have arduino, ibt2, 24v 250w 75rpm wheelchair motors, hall effect sensors and 24v power supplys.
    Just wantet to share my project and would appriciate feedback and thoughts from others ;)
  2. xFFBx Tearier
    xFFBx Tearier ffb Tearier Gold Contributor
    232Coins
    looks like we have similar builds! except i went with wood. ive got the same motors and just got it moving today. they have plenty of TQ! even at 18.5v. Yours is looking good man!
  3. Employee4Life
    80Coins
    Thanks, yes. I have been looking at your build recently. It looks great! I see you have mounted the motors in the middle. I was actully considering placeing the motors same as you, but went for the rear mount instead.
    Happy to hear it works and have good tq. I am still waiting for powersupply before testing my rig.
  4. Mario_Grao
    Mario_Grao New Member
    mechanical engineer
    Grado, Asturias, Principado de Asturias, ESP
    79Coins
    Hi:
    Nice beginning
    just as a sugestion. Ballbearing mount should be the last part to be welded to frame.
    It must be as close to CoG as possible, and you dont know were it si until complete structure is done.
    In my projet i did a complete preassemble, 2nd look for CoG balancing with me sitting on it , and last, weld it in the right position.
    Probably you have enough torque in your motors, but is not mi case and in this way you can reduce the needed torque.
    BR
  5. Employee4Life
    80Coins
    Hi! Thanks for the advice. I know what you mean, but due to not wanting to tear down my current sim rig and knowing this project will take a few weeks, I took a gamble :cool: Im sure i may regret my choise later. I also wanted to build it little bit adjustable due to other family members maybe wanting a try.
    I plan on mounting a electric adjustable car seat and make the steering and monitor on aluminiumprofil, so it can be adjusted up-down or forward-backwards with some manuall work.
    It could work or be a complete disaster, I will keep this thread updated :)
  6. xFFBx Tearier
    232Coins
    I’ll definitely be following your build to see how it runs!
  7. Employee4Life
    80Coins
    Mounted some aluminiumprofil too have the steering wheel and maybe monitor on. Still need make the middle piece where the mounting is going to be. Hope i will manage to make it adjustable and still be rigid and solid.
    Still not recived the power supply.
  8. Employee4Life
    80Coins
    I am starting to think the ballbearing is not going to work due to the rotation it also give. Might need the sort of other link or u joint.
  9. Mario_Grao
    mechanical engineer
    79Coins
    upload_2023-12-14_21-17-52.png I used this one
  10. Employee4Life
    80Coins
    Hello again! Sorry for not updating this thread, the truth is I have not made much progress befor yesterday, when i finally installed a proper joint link. Works good.
    Problem now, I am thinking if the 24v wheelchair motor is grounded. Because when i run one motor straight from the transformer, I can measure 24v from motion rig frame to transformer.
    Its a MY1016Z2 250w 24v 75rpm wheelchair motor.
    Anyone testet this motors before?
    Hoping for some clarity. Thanks!
  11. Attyla.pl
    Attyla.pl Active Member
    Polska
    1,336Coins
    The motor is unlikely to be grounded, I have the same motors only from a different manufacturer and they are not grounded, show in the photo exactly where you measure the current and it shows 24V.
  12. Employee4Life
    80Coins
    I thought so too, but I checked for resistence between motor and frame it was. I then connected one motor just to confirm that its actully correct, and then i measured 24v from transformer and frame. See picturers. Sorry for bad quality.
    I have since connected the motores to a bit of compressed plywood type of material, very strong, to avoid any problems with electricity to the motores
  13. Employee4Life
    80Coins
    Great news. Its alive!
    Waiting for the seat before i mount the steering wheel and pedals
  14. Employee4Life
    80Coins
    Update:
    After placeing the seat and had a sit in the rig with motion I think I need to redo some framework. The CoG is not centered on the joint and the motor mount and the arms(?) is to weak. I used a 8mm threaded rod from pivot to upper frame, this started to bend little bit. So need stronger connection there.
    All in all a little setback, but I find the building and thinkering very fun.
    Is there a way to limit/threshold the motor movement( how far the arm/piviots/ motor rotation move) in smc3?
    It feels like the potmeters are not sensitiv enough. It might be due to 1:1 ratio. I think if i make the potmeter input 1:2 it will work better. I use rubber band and plastic roller between the potmeter and motorshaft
  15. Employee4Life
    80Coins
    Potmeter and motor
  16. noorbeast
    153,788Coins
    +11,150 / 57 / -2
    Quick fix, sleeve the threaded rod with tubing over it, locked in place with a washer and nut either end.
  17. Attyla.pl
    Polska
    1,336Coins
    All solutions I've seen used a timing belt, rubber band can slip.
    1:1 ratio is OK , I have one and have no inaccuracies in reading the arm rotation .
  18. Employee4Life
    80Coins
    Thanks! Yes it is a good idea. I have also seen it on some threads here, I will look into it
  19. Employee4Life
    80Coins
    Update:
    The third time looks too be the final time. I think its ready for steering and pedals now.
    Have new joints between motors and frame, as well as sturdy motor mounts. Also put the electric on its own base as it was hard to change stuff with all the electrical in the lower frame.
    Enjoy some pictures of the latest version.
  20. Employee4Life
    80Coins
    I also took a run in smc3 and all works like a charm now. Rig feels very strong, as well as the motors.
    Moved the the lever very close to the motor shaft center to not have to wild of a ride. I feel it is very good now, just enough movement :)
