Question Mechwarrior 5 Spacemonkey Plugin ?
Discussion in 'SimTools Plugins' started by sci666, Dec 13, 2023.
  1. sci666
    1,210Coins
  2. hideki
    hideki Active Member
    Spain
    - 208Coins
    2DOF, SCN5
    I dont think Joystick input has Heave Movement like in the video.
  3. sci666
    1,210Coins
    Thats the point... Unfortunately no Informations in the Video and nothing on github
  4. sci666
    1,210Coins
    i tried to install it but i had no luck .... spacemonkey does something with openmotion and has a modded unreal engine launcher but it seems that there is no motion data .... nothing ...
    doenst work for me ...
    Setup
    1. Navigate to the MW5 sub folder inside the Space Monkey install folder.
    2. Extract the contents of MW5Mercs_0.3.zip into the game installation, there will be a folder named MW5Mercs containing two folders named Binaries and Content.
    Usage
    1. Go to the main interface of Space Monkey and select a main config for Open Motion.
    2. Go to the main interface of Space Monkey and press the Open Motion button.
    3. Press the Initialize! button.
    4. Space Monkey will now wait for a connection from Open Motion and output telemetry automatically.
    5. Navigate to the UnrealModLoader_V2.2.1 sub fodler inside the Space Monkey install folder.
    6. Launch UnrealEngineModLauncher.exe
    7. Launch MW5
    there is also a wreckfest solution ... idk if that works
    tested it in theorie ...wreckfest do some output for telemetry in 64bit mode
  5. sci666
    1,210Coins
    i got an answer on github. its definitly telemetry output, no xinput !!!! aaaaand it seems to work ... spacemonkey did the outputs !!!!
    was there a spacemonkey plugin in the dowload section, otherwise the output has Dirt4 format so maybe just start the Dirt4 plugin
  6. AstroNomad
    AstroNomad New Member
    16Coins
    Hello, thanks for posting this! And sorry to 'necro' this old thread. I was wondering if the telemetry from MW5 includes the position of leg rotation? Perhaps this is what position z is doing?
  7. paulopsx2
    paulopsx2 Active Member
    brasil
    648Coins
    So... it works ? I see telemetry and Good results on SRS ( sim racing simulator software ) but nothing about tô works on diy 2 or 3 dof on simhub or simtools...
  8. Benji85
    Benji85 Member Gold Contributor
    851Coins
    I'm having problems getting space monkey to talk to motion software. Any ideas? Thanks
  9. sci666
    1,210Coins
    i tried this long time ago and had no luck ... is there a spacemonkey plugin in the meanwhile ?
