  1. noorbeast
    153,710Coins
    Yes you are correct, sway should lean away from a corner and the roll DIR check boxes are set opposite of sway, this is what SimTools expects: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
    Please post pictures of all of your current SimTools settings, including the Tuning Center.
    The output from SimTools is the same for both axis, as long as the settings are the same for both axis.
    If the SimTools settings are the same for both axis but the rig does not respond the same then the issue is most likely the hardware and/or the Arduino control settings for the hardware.
  2. LemonIcetea
    LemonIcetea New Member
    123Coins
    3DOF, 6DOF
    The settings are going back and forth to test Smooth, but the basic settings are based on these photos.
    (Change to Advanced to add Smooth, etc.)
    You asked me to post the setting of the tuning center, but I keep looking at it as an output test of the game engine, so it's the default setting.
      202.5 KB
      476
      201.6 KB
      498
      408.2 KB
      489
    153,710Coins
    We need the pictures of your actual settings and I would suggest not using smoothing until all other issues are resolved and the base motion profile is fully sorted.
  4. LemonIcetea
    123Coins
    3DOF, 6DOF
    I'm sorry to make you misunderstand.
    Most of the tests were carried out in the above settings and faced the phenomenon mentioned.
    ( + The above settings use the presets provided by this thread.)
    The test for Smooth was saved as a separate preset and used.
    153,710Coins
    Thanks for the clarification.
    As I posted earlier the output from SimTools is the same for both axis, as long as the settings are the same for both axis.
    If the SimTools settings are the same for both axis but the rig does not respond the same then the issue is most likely the hardware and/or the Arduino control settings for the hardware, which you will need to check.
  6. LemonIcetea
    123Coins
    3DOF, 6DOF
    Guess it's not a matter of axis allocation?
    Also, is there any way to test the hardware? I'm using is Dof Reality's Motion Box.
    It's a necessary part of solving the above problems, but my simulator is currently moving Roll and Sway in the same direction.
    (Not used in the program, but operated the slider in the output test)
    So I think I need to check.
    153,710Coins
    Grab a copy of the SimTools manual and keep it handy for reference: https://www.xsimulator.net/community/faq/rtfm-start-with-the-official-simtools-documentation.117/
    The DIR boxes in Axis Assignments being checked orange or not determine which way an axis moves and as I have suggested sway should lean away from a corner and the roll DIR check boxes are set opposite of sway. In other words you should not have the DIR checked orange for both sway and roll, which is what you currently have.
  8. LemonIcetea
    123Coins
    3DOF, 6DOF
    I'm a little embarrassed that I didn't notice it was just a check box problem.
    Roll and Sway are set to contrast.
    I've seen the manual several times (not just now, but from a long time ago) but I couldn't check it out except for the output test of the game engine.
    The output test that I've said before was also included in the game engine.
    Is there any other way to test the hardware?
    Other hardware testing methods have been performed on the axis of the existing program (Sim Racing Studio), and in that case, this stair phenomenon has not appeared, so we are still working on it to resolve it.
    (I'm continuing to mention SRS because I'm in the process of moving from SRS to SimTools which was used by our programs..
    There is also a reason why some people used SRS and moved to SimTools like me.
    If it's a problem, I'll delete it.)
    153,710Coins
    I don't use SRS, so can't comment on that.
    But I stand by my earlier comment, with the exception of the language setting issue, if the SimTools settings are the same for both axis, but the rig does not respond the same, then the issue is most likely the hardware and/or the Arduino control settings for the hardware, which you will need to check.
    My understanding is that DOFreality uses SMC3, so the SMC3 Utility, used to configure SMC3 settings, is readily available: https://www.xsimulator.net/communit...3dof-motor-driver-and-windows-utilities.4957/
    I believe that like all rigs it is important to properly balance a DOFreality rig.
    But being a commercial rig I would suggest contact with the manufacturer before messing with the rig or SMC3, as really that is where support responsibility resides.
  10. LemonIcetea
    123Coins
    3DOF, 6DOF
    Thank you very much for all your kind answers so far.
    I am planning to contact the manufacturer.
    There may be users who have similar situations with me, so if I solve these problems, I will write about the progress and the results
  11. Rusty_Pilot
    Rusty_Pilot New Member
    39Coins
    Hi everyone,
    I have had my P3 for about a 1.5 years. It has a "flat" on the front left roller. (It cracked) I saw the post back on page 14 saying it is a 27mm roller. Being in the US, it seems impossible to find. I was wondering if anyone had a good source to get replacement wheels online, know of a good alternative, or should I just upgrade to the P6? Bit extreme, but I have been thinking about for awhile. This might push me to the P6 upgrade kit.
    153,710Coins
    Is the roller unavailable via DOFreality?
  13. Michail
    748Coins
    Maybe can someone tell me the specification of the Lift support gas damper? How many Nm they have?
  14. Radioproffi
    Lviv
    1,677Coins
    340 or 450 Nm
  15. Gadget999
    12,132Coins
    how much is the DOF H3 ?
  16. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    2DOF, DC motor, SimforceGT
    HHello forum people, it's been a long time... Could you tell me the specifications and the exact model of the potentiometers that the DOFReality simulators use to put in my simulator?
    153,710Coins
    Can you please post a picture of the potentiometer used, most have some sort of identifying part/serial number.
  18. Radioproffi
    Lviv
    1,677Coins
    different potentiometers were used in different years, you need to look at which one you have installed
  19. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    Hello sir, thank you for responding... I actually wanted to know what types of potentiometers DOFREALITY uses. I want to install some durable, precise, and Hall sensors. What potentiometers do you recommend? I have two Arduinos, two H-bridges, and four cricket motors in my simulator with SMC3.
  20. Radioproffi
    Lviv
    1,677Coins
    Hello everyone!
    We are excited to announce the upcoming release of new motion simulator models featuring 4 Degrees of Freedom (4DOF): Roll, Pitch, Yaw (Traction Loss), and Heave.
    The lineup will include the DOF Reality H4, and the DOF Reality P4 will also be available — both platforms deliver enhanced motion realism and a deeper level of immersion.
    https://youtube.com/clip/UgkxmZTJCy5liVTiI_pI8TjdH_d-bkvFO0x8?si=SMgK4o7vo9QUy3mn
