Question 4DOF : co-planarity ?
Discussion in 'SimTools Pro & Entertainment Version' started by vthinsel, Dec 19, 2023.
  1. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,056Coins
    Arduino, 4DOF
    Hello !
    I'm about to move to a 4DOF (traction loss will come later) and I was wondering how co-planarity could be ensured. Let me explain briefly: with 4 DOF, all actuators need to move in way that the rig remains a plane: we do not want to twist the rig, and make too much efforts of the actuators. Can simtools enforce this in some way ? I could add basic calculation on arduino just based on Z of all actuators, but it would probably be more accurate/faster on simtools.
    Thanks !
    153,986Coins
    +11,162 / 57 / -2
    Could you please post a sketch of what design is intended that gives the 4DOF.
  3. vthinsel
    FRANCE
    6,056Coins
    Arduino, 4DOF
    Sure. It will be an sfx-100 based rig, but using 220mm stroke (SRT-80 actually):
    Diablo2112's 4-axis SFX-100 build (xsimulator.net)
    When the four actuators will be attached to a bottom frame for traction loss, we must ensure they are coplanar. I have some arduino code almost ready, just for fun and safety of the actuator/rig
  4. yobuddy
    51,551Coins
    As long as you run them all from the same controller, you will not have any problems.
    I have seen it work even when multiple controllers are used also, but one controller is safer because if it has a problem, all axis stop.
    I'm also thinking of adding an option to stop all output if any connected interface reports an error. (As it would be safer for these kinds of sims when running multiple controllers.)
    Take care!
  5. Mycroft
    Mycroft New Member
    47Coins
    Motion platform
    That would be great!
    I'm using a prosimu 5M platform with 2 controllers, and I regularly have 1 controller that fails while the other continues to work
