starting budget 2dof to 3dof racing sim
Discussion in 'DIY Motion Simulator Projects' started by stahl2005, Dec 23, 2023.
  1. stahl2005
    stahl2005 New Member
    34Coins
    So far i went to the local scrap yard and bought as much 1 1/4" steel tubing they had. It was a total of 17 bux worth maybe 7 pieces 60 inches each. I managed to put something together over the last couple days, figured i would share my build.
  2. stahl2005
    34Coins
    Here is the universal i made from a drive shaft i took both ends and just put them together getting rid of the center of driveshaft
  3. stahl2005
    34Coins
    Here is the base i build out of a round tube frame and some of the square tubing i bought. I used angle iron so i can adjust universal forward and back as needed.
      544.6 KB
      163
  4. stahl2005
    34Coins
    Here is a picture of my seat it is from a 2008 hhr. I built a box under it and put 3 of the square tubes together to start my frame for the upper section.
      458.6 KB
      165
  5. stahl2005
    34Coins
    It is together now enough to race again Im using 2x4 blocks to hold seat still until i get motors and everything hooked up. Only thing missing in that picture is the actual pad for the shifter and ebrake. I will take pictures of that as well. Mounts are built for motor i just have to add them and attach rods they will mount right under the front of seat. I purchased 2 24v 20amp power supplys on amazon. I have a 12v 20amp power supply for power seat as well.
  6. stahl2005
    34Coins
    here is cad drawing i came up with for monitor stand and the stand put together from 6 scrap 8 ft 2x4's
  7. stahl2005
    34Coins
    didnt fix gaps yet they are really close just have to figure out my angles first they are around 120 degrees now monitors are lg 32" 32gn600-b almost no bezel the mounts i used were from harbor freight they were 10 dollars a piece on sale
  8. stahl2005
    34Coins
    made a set of gears to run from motor to a homemade hall effect sensor figured id throw up the drawing for you guys and get to printing
  9. stahl2005
    34Coins
    this is the pedal motors i made l298n motor drivers and pro micro running in simhub motors are from old playstation controller large weight motor on brake pedal and smaller on gas pedal
