FSX
Discussion in 'Flight Simulator X' started by Gerardo Rivera, Dec 1, 2023.
  1. Gerardo Rivera
    Gerardo Rivera New Member Gold Contributor
    114Coins
    Box FSX motion not working when dropped in FSX Steam plugin.
    153,764Coins
    +11,149 / 57 / -2
  3. Gerardo Rivera
    114Coins
    Here are the settings
    153,764Coins
    +11,149 / 57 / -2
    @yobuddy any thoughts re this plugin issue?
  5. yobuddy
    51,526Coins
    Here is the simconnect version you want to use with the plugin.
    It gets auto installed when installing the plugin, but if other versions are already on the system, it may not be used or installed. (It's v10.0.62615.0)
    If your system has other versions installed, please remove them from the system so we know the correct version is being used. Both the box and the steam version of the game has been confirmed working, so this should fix your problem buddy.
    Take care,
  6. Gerardo Rivera
    114Coins
    Yobuddy, I did the plugin reinstalled then dropped the FSX .exe launch with no problem but still no motion. Here are the screen shots of the setting
  7. yobuddy
    51,526Coins
    Please install this simconnect version and give it another go.
  8. Gerardo Rivera
    114Coins
    Yobuddy I deleted the simconnect installed the last one you sent still no motions and the settings I sent
  9. yobuddy
    51,526Coins
    The first simconnect I posted is the one for fsx, the second one is for Prepar. (but we have both installed so I sent you both)
    You do have some stuff installed that I don't thou.
    What does the plugin listed below do?
  10. Gerardo Rivera
    114Coins
    That is for my flight radio from Logitech
  11. Gerardo Rivera
    114Coins
    That is the flight radio from logitech
  12. yobuddy
    51,526Coins
    It is possible the flight radio uses a different simconnect than the plugin does, as it looks to be a hardware device that communicates with the game?
  13. Gerardo Rivera
    114Coins
    I will deleted and try and let you know,
  14. Gerardo Rivera
    114Coins
    @yobuddy deleted the flight radio did new steam Fsx installed dragged the box Fsx to the steam banner and no change launch the flight sim but no motion. But what is crazy I installed prepar3d plug in and dropped the exe from my prepar3d tested I get motions then dragged my box Fsx to the prepar3d and it launch the box Fsx with motions. I like to keep prepar3d stand alone because I got different payware aircraft that are not available on Fsx.(maybe this will help determine when I launch the box Fsx that was dragged on the steam banner the rig makes sound like is getting inputs from the simulator but no motions after)
  15. Gerardo Rivera
    114Coins
    Need help with Box FSX the steam FSX plugins is not working when dragged box FSX to the banner, Box FSX launch but no motion from the rig.
  16. Gerardo Rivera
    114Coins
    @yobuddy,
    I purchased FSX Steam it works with simtools got motions but when dropped Box FSX on the FSX banner lost the motions of the rig. See attached files
