Question Finding Motors
Discussion in 'Motor actuators and drivers' started by _cOdaC_, Jan 7, 2024.
Tags:
  1. _cOdaC_
    _cOdaC_ Member
    319Coins
    Hi guys, I‘m totally new to the topic.
    I‘m following a project with the following Motor Specs:
    Simukit
    440W
    1:60
    3000rpm
    24V
    Unfortunately, the Simutkit Webside is offline for a while. Can you recommend a similiar motor and probanly a vendor shipping to Germany?
    I‘m searching since days now and found no adequate motor…
    Thank you guys.
    153,703Coins
    There may be second hand powered wheelchair motors available locally, if you hunt around.
    You could order from China.
  3. tselehub
    tselehub New Member
    98Coins
    can i use steper instead of wiper motor?
    153,703Coins
  5. tselehub
    tselehub New Member
    98Coins
    I know you can cut the ground and its ok.One last question. I'm waiting for the wipers to arrive and I already have all the other things. Where does the power supply get its power from? I see the connections in all the guides, but I haven't figured out where the power supply gets its power from.
    153,703Coins
    The PSU(s) plug into mains power.
  7. tselehub
    tselehub New Member
    98Coins
    Mains power?
    153,703Coins
    Your house power outlets.
  9. tselehub
    tselehub New Member
    98Coins
    With cable? What cable? What connection?
    153,703Coins
  11. tselehub
    tselehub New Member
    98Coins
    i have this https://www.ideahellas.gr/product/trofodotiko-500w-12v-40a-gia-led-kameres-klp-andowl-q-d40a-asimi
    what need to power it? i dont see a PORT for cable like pc PSU
    153,703Coins
    Where are you located in the world?
    You will need a power plug and cord for whatever applies in your part of the world.
    That gets wired into the PSU, which changes whatever the voltage is that is used for appliances in your part of the world to 12v.
  13. tselehub
    tselehub New Member
    98Coins
    EUROPE, can you show me a photo?
    153,703Coins
  15. tselehub
    tselehub New Member
    98Coins
    Of course, I'll take it to an electrician!
  16. gingercat
    gingercat New Member
    Software Engineer
    Nr Lancaster, UK
    131Coins
    DC motor, SimAxe, Arduino
    In that pic above, live and neutral appear to be connected the wrong way round - at least here in the UK live is brown, netural is blue. Not sure if it matters for that PSU.
