2dof simple wipermotor chair by ua6aak
Discussion in 'DIY Motion Simulator Projects' started by ua6aak, Jun 18, 2010.
  1. ua6aak
    ua6aak New Member
    Russia, Yeisk
    470Coins
    2DOF, DC motor, Motion platform
    Welcome all enthusiasts!
    I would like to submit my design of a simple simulation based on the idea DERIY.
    Several videos.
    http://www.youtube.com/watch?v=GugCts33zt0
    http://www.youtube.com/watch?v=z6IdoibudRo
    http://www.youtube.com/watch?v=IdeB29UTcXQ
    Homemade joint:
    Lower platform:
    upper:
    assembly:
    chair:
    more:
    Many thanks to:
    sirnoname (software)
    Thanos (AMS and H-bridge)
    DERIY (layout)
    and all other enthusiasts!
  2. Frakk
    Frakk Active Member
    328Coins
    Congratulations, you have done a great job! :clap:
    I really like the pivot under the seat and the wood construction. Can you give a rough estimate of the price, everything included?
    It's good to see more and more builds finishing with great results!
  3. wimpo`
    wimpo` Member
    metselaar
    nederland, twente, vroomshoop
    178Coins
    excellent it's a very nice build. :clap:
    You got some highres pictures, i can't click them it seems.
    congratulations again :cheers:
  4. ua6aak
    ua6aak New Member
    Russia, Yeisk
    470Coins
    Frakk, thank you for your response!
    About the approximate price: whipers - about 50 Euro, chips, transistors, some bolts and nuts - another 50 euros, the rest was found in the garage.
  5. ua6aak
    ua6aak New Member
    Russia, Yeisk
    470Coins
    Sorry for the incorrect links!
    Again.
  6. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    421Coins
    Great job!
    Btw, you could take a lot of stress from the actuators by placing the pivot under your butt.
    As it is now, your weight is splitted between the pivot and the actuators, which is suboptimal Imho.
    Regards
  7. wannabeaflyer
    wannabeaflyer Active Member
    UK - London area
    974Coins
    Have to say wow wow wow , another great project and again you guys have shown a level of innovation and ways to make it simple , love the way you made your own universal joint and revesre thinking about actuator location -- creative thinking at its best :) every day you guys show waht can be done without spending a lot of money .. personal thanks for posting your work . i have all the bits to make my sim but always on the lookout for easier ways to make bits with limited tools. your work and Deriys show a lot of useful details love it love it lovie it ----greta work guys
  8. wannabeaflyer
    UK - London area
    974Coins
    by the way forgot to ask --- is that a vibration pad seat your using on your wooden seat --- i have one i bought as a massage seat for my long car journeys -- always wondered if i could convert it to force feedback LOL:) my one has several small vibrator motors in the cushion ? is that what you used ?
  9. ua6aak
    ua6aak New Member
    Russia, Yeisk
    470Coins
    Yes, that it is. And now we must try to connect it in parallel with one of the wipermotors, as massage seat is powered by AC through a built-in rectifier!
  10. ua6aak
    ua6aak New Member
    Russia, Yeisk
    470Coins
    No, no. In the middle position a chair with my body balanced. This balance is easily obtained by moving the chair along the upper platform. In the video, visibly as bouncing the front edge of the lower platform. This suggests that the center of gravity is located exactly over the hinge.
  11. Stikk
    Stikk New Member
    0Coins
    Hi there,
    I've never built a simulator before but I'm interested in giving it a go. This one looks awesome, it's cheap and appears to be relatively easy, any chance you'd be interested in posting some detailed instructions so I could build something similar? :D
  12. ua6aak
    ua6aak New Member
    Russia, Yeisk
    470Coins
    This simulator was built from scrap materials except vipermotors.
    To control the motors used Tronic's AMC motor motion-controller and Tronic's DIY dual Mosfet H-bridge (DSMhb).
    Power supply is 20A 13,8V.
    Basic dimensions:
    -bottom platform
    -upper platform
    -hinge
    -crank
    -chair
  13. fredspeed
    fredspeed New Member
    Northern Norway
    418Coins
    Hello ua6aak. I really like yours and Deriys sim, and I am building something thats a combination between them. Have you thought about making steering wheel and pedal move with the seat, as Deriy`s? What kind of powe supply do you use? show a picture of it! I see Deriy use 16v and you 13,6v. I guess you both have 12v motors.
    Fred :thbup:
  14. ua6aak
    ua6aak New Member
    Russia, Yeisk
    470Coins
    Hi, Fred. I use a power supply designed to power the radio amateur transceivers. It is 20 amps 13.8 volts. About making steering wheel and pedal move with the seat - I think it is quite possible. Perhaps'll do this in wintertime.
    I wish you success!
  15. fredspeed
    Northern Norway
    418Coins
    I think it is posible to move steering wheel and pedal with seat if you make it low weight. You are velkome to have a look at my design here: articsimulator-joyrider-made-of-wood-t2063-50.html I am using laminated wood on the curved parts. (its not fully tested) :highfive:
  16. obisk
    obisk New Member
    tot suchen hier im forum
    Kalsruhe
    0Coins
    ua6aak
    how strong are your wiper motors?? (W??)
    and how fast per min ??
    thx
  17. DERIY
    DERIY Member
    RUSSIA
    - 52Coins
    He used the same engines as in my simulator.
    http://www.kzae.ru/products/reductors/product3.shtml
    Rated voltage 12 v
    Rated power 10 W
    The maximum current 3,5 A-5,0 A
    Rated speed low 30-40 rpm hi 55-70 rpm
    But the power consumption of these engines is about 60W
    With supply voltage 12 volts.
  18. ua6aak
    ua6aak New Member
    Russia, Yeisk
    470Coins
    This is true!
  19. Deleted member 4120
    Deleted member 4120
  20. ua6aak
    ua6aak New Member
    Russia, Yeisk
    470Coins
    Hi everyone!
    A slight modification of my Sim. Now fullmotion.
    http://www.youtube.com/watch?v=0C4lKZl5d2U
    http://www.youtube.com/watch?v=DzjzkT5nyBk
