Need help with SMC3
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Tim Herschbach, Jan 12, 2024.
  1. Tim Herschbach
    Tim Herschbach Member Gold Contributor
    585Coins
    I'm trying to get my motors to respond but I don't really understand how to use SMC3. I have 2x 24v PSU's; 2x IBT2's 24v; 2x 75rpm, 24v, 250w motors; ard uno r3. Pots are 360 hall.
    I've followed these steps as best I can For #6, I don't see a "Clip" or a "Limit". I have "Max Limits" and "Clip Input" so I set those to 255.
    8. Set Kp to about 400
    My motors do nothing. They were initially "twitching" back and forth when I plugged in the uno but when I loaded up SMC3, they stopped. How do I proceed? Thanks so much.
      326.1 KB
      251
      295.2 KB
      249
    152,971Coins
    +11,115 / 56 / -2
  3. Tim Herschbach
    585Coins
    Sorry, I set Mode 2 already.
    I've read through those parameters several times, but I'm still not sure how to use them to get the motors to spin. It's not written for someone who isn't experienced in this stuff. For example, what is PID? Are my settings in the above ss correct?
    152,971Coins
    +11,115 / 56 / -2
    It takes time and research to learn anything new, and there is a bunch to learn when it comes to DIY motion rigs, which is where the FAQs come in as a handy starting point for any initial questions: https://www.xsimulator.net/community/faq/
    Here is a gentle introduction to PID, written with another controller in mind, but the analogy is a handy way to wrap your head around PID, and you can always dive into deeper technologically more accurate descriptions once you have a basic understanding, if you ever feel the need: https://www.xsimulator.net/community/faq/a-laymans-analogy-guide-to-pids-pid-tuning.219/
    The SMC3 setup steps should be followed first, before getting into the rest of the settings, to make sure it moves as expected. If it does not something is wrong and needs to be fixed.
    Initial Setup
  5. Tim Herschbach
    585Coins
    Thanks Noor, I included those initial steps in the OP to indicate I had already done them. I apologize if that wasn't clear.
    On a hunch, I disconnected the pot belts and sure enough, it's responsive now... I can make the green line move around by rotating the pot by hand and the motor goes one way or the other depending on which side of the neutral I'm on. So that's good news. Tomorrow I'll have more time to dive into the above info if needed.
  6. Tim Herschbach
    585Coins
    I've got both motors and pots centered and they're responding as expected. I'm assuming SMC3 is writing these parameters to the ard? I can't find anywhere a description of what it actually does other than control the motors. The reason I need to know this is because I don't want the limits I've set to disappear if I'm not running SMC3 and put a hole in my floor and break off the pots.
    So does SMC3 actually make changes to the ard or is it just to make sure the motors are moving correctly before going into SimTools?
    152,971Coins
    +11,115 / 56 / -2
    Yes the SMC3 utility purpose is to set the values in the SMC3 code on the Arduino.
    You can't run SMC3 and SimTools and the same time, as that would create a port conflict.
  8. Tim Herschbach
    585Coins
    Thanks, someone before told me SMC3 doesn't change the code which is what caused my confusion. Everything is working now, just doing lots of tweaking.
  9. Jango
    Jango Member
    Mauritius
    366Coins
    2DOF, DC motor
    Hi Tim, I am building the same setup as yours.
    I have looked at the tutorials and could not see anyone centering the lever arm (attached to the motor shaft).
    My question is:
    - is there a setting to centre the arm (so it has equal room to move up or down) and then zeroing the potentiometer and finally connecting all mechanical links?
    - or do you disconnect the sensor belt, manually rotate the motor shaft to the centre position, zero the potentiometer and then connect everything?
    My motors (similar to yours) are on their way and I'm not sure whether I can turn the shaft by hand as it has a gearbox.
    Thanks.
    152,971Coins
    +11,115 / 56 / -2
    You need to disconnect the sensor belt, manually rotate the motor shaft to the centre position, zero the potentiometer and then connect everything.
