Dashboard for Wheel Base FANATEC
Discussion in 'DIY Motion Simulator Projects' started by SAKURAMAN, Jan 16, 2024.
  1. SAKURAMAN
    SAKURAMAN New Member
    230Coins
    Hello everyone, after a very long period of inactivity on my simulator and the forum, I thought it was time to share my Dashboard with you. Here's a short description of the design of my dashboard, which will fit perfectly on my FANATEC ClubSport Wheel Base V2.
    First, the design of the layout, in the style of the SRX, but better.......
    After listing the various accessories and locations, here's my plan.
    Now double-sided glued to 5mm Plexiglas. Two 50cm x 25 cm x5cm boards.
    Then cut... and sand....Patience.....
    Prepare the cover, which will be made of small pine laths glued together with cyano, then sanded and resinated with glass cloth.
    Length of pine strips 185 mm x 5 mm
    The main components have been purchased here:
    http://www.symprojects.com/
    Shopping list.......
    1 DLC-247
    1 Fan Controller
    1 Pro-Gauge Controller
    1 DEPO Racing 95mm Electronic Speedometer
    1 52mm water temperature gauge with 7-color backlight.
    1 52mm oil temperature gauge with 7-color backlight.
    1 52mm oil pressure gauge with 7-color backlight.
    1 52mm fuel gauge
    1 95mm tachometer
    1 Pro Shift, a compact, easy-to-use board that lets you manage up to 16 LEDs
    3 0.36" Six digit displays for DLC-247
    1 Display 0.56" display for DLC-247
    1 0.56" three digit display for DLC-247
    3 DLC-247 splitter pins
    1 JC32 Joystick Controller
    24 leds 5mm colors
    Many cables.....
    1 USB 2.0 splitter
    Pro Shift for 16 leds
    The Controller Pro-Gauge meter management card
    The card for the button box. The JC32
    Manufacture of 2x12 leds of 5 mm colors
    3 red leds, 3 blue leds, 3 yellow leds, and 3 green leds per side.
    Mise en place, découpe à la perceuse à colonne et scie cloche diamètre 50mm pour les compteurs.
    The USB 2.0 splitter
    A quick blank test !!!! It works !!!!
    We assemble to see and test.... So many cables!!!
    We dismantle everything ...Then install the solar film carbon 3M DU BON... COOL
    Let's go back up....
    A little adhesive for imitation sheet metal.
    Black alcantara upholstery spray-glued inside and out.
    Connection and testing
    Change meter colors as you like. Cool
    Fanatec force feedback pose
    It's perfect for me...
    Now I wouldn't be able to do without it, as it adds so much realism to our simulator and passion for the game.
    I would like to thank Symproject for their seriousness and advice.
    The Button Box Suite.....
  2. harrie
    harrie Member
    coevorden
    221Coins
    Arduino, 4DOF
    verry nice design and layout , i like it . i was looking for something like that for my ferrari build . are there cad drawings for this project ? for cutting out on my cnc machine. would love to make this idee , looking good ! nice job .
  3. SAKURAMAN
    230Coins
  4. SAKURAMAN
    230Coins
    Hello, glad you like it, currently I no longer have the plans because my computer has failed me, I think I can find them from a friend to whom I gave them. As soon as I have them I will make them available...Manu
