24 dc motor not running
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by jarena, Feb 4, 2024.
  1. jarena
    jarena Member Gold Contributor
    126Coins
    Hi guys,
    So I was looking at the you tube videos of D Max and decided to start a sim project.
    I have two 24v motors that I want to run the sim with. start to do the connection on the arduino and one IBT-2 to try one motor at the time to make sure everything works.
    did all my connections including the pot, in the arduino i downloaded the software to for sim utilities. when I turn on the sim utilities it detects the arduino on com 4, so that's good. then i put motor 1 on to play with pot and the green line moves up and down as I turn the pot so that's good also. but when I connect the 24 volt to the IBT-2 , the output to the motor I have nothing going to it. what am I doing wrong?
    153,710Coins
  3. jarena
    126Coins
    thanks for the reply, i will post pictures soon. just to make sure i have the right SMC3 can you direct me where i can get this?
    153,710Coins
  5. jarena
    126Coins
    ok so re program the arduino with the smc3 , change it to mode 2 . again the pot I see the green line going up and down when I move the pot. but if I put the sim utility to motion nothing is happing to the motor. I check the output for the motor on IBT-2 and the is no 24v coming out i have 0 volt. here is the image of my connection re check all of my connection to make sure and all is done correct.
  6. jarena
    126Coins
    can I remove the pot just to see if I can motion just with the smc3 utility? and see if motor moves?
    153,710Coins
    Please post pictures of all of your SMC3 settings.
    A pot provides positional feedback for the motor.
  8. jarena
    126Coins
    here is the picture. so if i move the pot green line goes up and down
    153,710Coins
    I am presuming the wiring is complete as per the SMC3 instructions and the pot is attached to the motor, is that correct?
    From the image it seems PWMmax is not set, step 9 in the initial SMC3 setup:
    8. Set Kp to about 400
    Once that is done can you please run the Sine test in Out Mode and post a picture of the result.
  10. jarena
    126Coins
    quick question do I have to have the pot attach to the motor in order to just run a test? can I just have the pot connected and turn it up and down in order to see if I get movement from the motor? basically is to a bench test before I assemble the motor with all the wiring to the rig.
    153,710Coins
    The pot can be tested in SMC3 with the motor turned off, but should be connected to the motor for a proper test, as the pot provides position feedback of the motor.
  12. jarena
    126Coins
    ok so tested again, when I do step 9 it's the yellow line that moves towards the blue not the green. so something is not right some where can you tell which connection is wrong?
  13. jarena
    126Coins
    so recheck my connections and now i am sure 100% that everything is connected right from Arduino to IBT with pod and also power supply. check with multimeter continuity and a that is good check also the 5v power supply and that is good also. now on to the the programming which is what i suspect is my problem. My Arduino is connected on com 4, what I need to now is what is the program that needs to be load to Arduino to be visual by the simtool. if someone can attach the file and give me steps on the how to of it all would greatly be appreciative of this. Keep in mine the motor I will be using is 24v, 3000rpm, torque is0.43nm, amps 8.4. thanks
    153,710Coins
    As per pre previous posts SMC3 would be a good option, following the setup for your control board and configuring the SimTools interface as per the SMC3 instructions: http://www.xsimulator.net/community...3dof-motor-driver-and-windows-utilities.4957/
    Do not run the SMC3 config program at the same time as SimTools as that will create a port conflict.
  15. Attyla.pl
    Attyla.pl Active Member
    Polska
    1,336Coins
    First, the motor will not start until the button next to Motor 1 is off, click it and switch it to ON
    Secondly, set Fpwm to 20mHz because you will burn IBT2
    Third, set the green line in the middle of the screen and set the PWMmax to 120-130 and gently turn the potentiometer the motor should start
  16. jarena
    126Coins
    Thanks Noorbeast for your patients. got everything working. now onto building the rig. was looking at something like what D-Max built not the big 3 way one, but the small version of the 2 dof version. i'm about his size and height so was wondering if anyone can give me the dimension of the base and also the dimension of where the seat will sit on the u joint with pedal stand and steering stand. thanks
    153,710Coins
    The FAQs have some member submitted rig dimensions: https://xsimulator.net/community/faq/cockpit-design-dimensions.116/
