presentation
Discussion in 'New users start here - FAQ' started by Fabrizio Penzo, Feb 3, 2024.
  1. Fabrizio Penzo
    Fabrizio Penzo Member
    137Coins
    Hi to all
    im new of this world but im very excited, i put on my chair the bas shaker 1 months ago and naw ...i wanna more .
    id like to make a simulator like the same of d-max for car racing but i think it 'll be a long way for a beginner like me in the wire and connection and software but i wanna do it .
    I've a question i was reading for the wiring diagram for arduino but i found only the way for 2 motor have someone the picture for the 3 motor like d-max video ? i can't find it
    thanks a lot
    151,467Coins
    +11,041 / 56 / -2
  3. Fabrizio Penzo
    137Coins
    thanks a lot
  4. Fabrizio Penzo
    137Coins
    another question im loking forthe 3 motors but here in europe i can't find the same of the video
    Worm Drive Motor 12V/24V 200W, 180 RPM, 20Nm Torque
    someone could help me to find motor like this specification here in europe ? or another model ? thanks a lot
  5. Trent Robinson
    Trent Robinson Member
    Systems Engineer
    354Coins
  6. Fabrizio Penzo
    137Coins
  7. Fabrizio Penzo
    137Coins
    Sorry guys im a little bit became crazybto find one ,its all day i chek on web and foe me is a labirynt ,the link in the description dont run and remaind me to a lot of product were im lost 12,24 rpm ratio i became crazy to find nothing ....there is someone post me a direct link for the exact product i can buy in europe/italy ?
    Sorry again im less than beginner
  8. Fabrizio Penzo
    137Coins
    I fondi a lot on alibaba but I dont know wich is theright choice i was looking for double shaft in the optio you can have so I have no problem with potentiometer i faind tgis one but on tge model 50:1 he say 60 rpm ...please help me find one they sjip to italy ...thanks
    https://x.alibaba.com/AveoJg?ck=pdp
  9. Fabrizio Penzo
    137Coins
  10. Fabrizio Penzo
    137Coins
    Other question again sorry
    I was loking the wiring diagram , inediti to buy also the smc3 tool from the arduinonand pc or i go directory on pc with onlybarduino ...im making confusion
  11. Trent Robinson
    Systems Engineer
    354Coins
    The eBay crab pot will ship international. If you really want that motor. Otherwise, you could do wheelchair motors which are more obtainable in your area perhaps.
  12. Trent Robinson
    Systems Engineer
    354Coins
    I don't follow your question. You need an Arduino Uno R3 to install the smc3 sketch on. You connect that Arduino to the computer that will run simtools. Your motor controllers and potentiometers will connect to the Arduino.
  13. Fabrizio Penzo
    137Coins
    Ah ok sorry my brain is fused i bad explain i dont need the monster motor shield
  14. Trent Robinson
    Systems Engineer
    354Coins
    There is a large section on Motor Drivers in the FAQ. From experience, I highly recommend you spend a few hours familiarizing yourself with the various FAQ's. There is a ton of information that will guide you through the learning curve.
    The monster motor shields are simply an alternative motor driver. Motor drivers (xsimulator.net)
    151,467Coins
    +11,041 / 56 / -2
  16. Fabrizio Penzo
    137Coins
    Thanks a lot i ll try to understand wich is the easiest way
