Question Heave Concepts
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Sebastian2, Dec 30, 2023.
  1. Sebastian2
    Sebastian2 Active Member
    476Coins
    Hi folks, I'm currently in the planning phase of a DIY motion simulator with 3 DOF - pitch, roll and heave.
    I took looks at a lot of rigs presented in this forum and noticed that most 3DOFs with heave utilize a concept where the gearboxes have output shafts on both sides, and both levers are then connected to a quite massive structure that is shaped like an inverted U, with some form of U-joint on top, that connects it to the platform. It's tough to describe geometry using words, so take a look at the attached picture.
    These rigs usually utilize a heim joint / rose joint / ball joint / rod end bearing (whatever it is called in your flavor of the english language) to connect the inverted U-shape with the platform. I've spent some time looking but I can only find such joints with angular motion ranges of about +/-14 degrees. I found versions with about 17 degrees but those were massive, like 20+ mm diameter of the holes. I want to stay in the 8...12 mm ballpark.
    Currently I am aiming for a rig that can do +/-20 degrees, so the commonly used rod ends don't seem to work for me. Or can you folks show me where to find a rod end with a wider range of motion?
    Maybe I should use a different heave concept for my rig?
    I found a few people using a single central U-joint like in a 2 DOF, but it's movable in the vertical direction. The motors are also connected like in a 2 DOF (of course, there are 3 motors for the 3 DOF) , with a single thin push rod connecting the motor levers with the top platform. I also attached a picture showing this concept.
    This concept uses a standard U-joint which easily can achieve a wide range of motion. It's also quite simple do a assisted heave system this way, just put a spring under the U-joint.
    However, I'm struggeling a little transforming the idea of making the central U-joint movable into an actual construction. Should I use cylindrical rods that move through cylindrical plain bearing bushing, like in the attached picture? Or should I use linear guide rails? I'm afraid to miss out on a easy and good solution just because I don't know about what hardware exists out there.
    I have not found many implementations of this heave concept to inspire me. I know of noorbeast's DX rig, but I don't want to utilize this office chair mechanism, although it's a clever way to do it. Do you folks know of more rigs that implement heave via central U-joint?
    Best regards
    Sebastian
    153,728Coins
    Try the Enhanced Google Search on the Recent page of the Desktop site, with the term Heave Assist to find related projects and various approaches.
  3. Michail
    748Coins
    Question is the y style ctc possible if the motor have shaft only in one side?
  4. Sebastian2
    476Coins
    I think it would be hard to create a mechanism that has the necessary stiffness. The common double shaft inverted y structure is quite stiff against forces directed parallel to the motor shaft. I think you would need to have quite a long single shaft and special motor levers to even get close to that stiffness.
  5. Michail
    748Coins
    So I go with u joint mounted on linear rail guide.
    I am wondering why they using 4 instead of 1 or 2 for example. I need only stabile not heave assist. Because I will use gas damper.
  6. Sebastian2
    476Coins
    Again, it's about stiffness on the horizontal plane. 4 vertical guide rails, spaced somewhat apart and interconnected with a stiff mounting, will be stiffer than one single guide rail, even if it was 4 times the weight.
    Also, 2 columns would provide more stiffness in one direction that in the other, which would not make much sense. 3 could to the trick but you would need triangular mounting plates on both ends. Rectangular mounting plates for 4 guide rails might be easier to make. After all, the cost disadvantage of 4 vs. 3 guide rails is marginal, compared to total cost of the rig.
  7. Michail
    748Coins
    I will go with four rails.
