Question Motors not responding in simtools
Discussion in 'SimTools DIY Version' started by Simulator Jicin, Feb 21, 2024.
  1. Simulator Jicin
    Simulator Jicin New Member
    Czech Republic
    110Coins
    Hi guys, I need help. I have wired up my DIY setup with two wiper motors, and when I test it in SMC3 it works fine. When I set up simtools, and try the output testing, it doesnt work. upload_2024-2-21_19-37-52.png
  2. yobuddy
    51,524Coins
    The SMC3 app and SimTools can not run at the same time, if that was the problem?
  3. Simulator Jicin
    Czech Republic
    110Coins
    This is not the the issue, when I move with the sliders, i hear noise from the motor, but it doesnt move. Could the problem be that the potentiometers are not already mounted directly to the motor?
    153,728Coins
    The pots provide positional feedback for the motors, so been to be connected.
  5. yobuddy
    51,524Coins
    Do you have any axis settings for the default profile?
    I suggest testing out SimTools v3, its a free update, and you can use the same license you use with v2.
  6. Simulator Jicin
    Czech Republic
    110Coins
    I have the exact same settings as Dmax has in his video tutorial. I will try to mount the pots today
