value1
Wreckfest Plugin 2.0.1.3
Simtools game plugin for Wreckfest 32bit
  1. sci666
    1,210Coins
    may work but why is st2 not detecting "running game" if spacemonkey is started ? i jsut want to use it for another game as well ..mechwarrior 5 ! but no luch to get it to "game running" ....WHY :((((((
    i just need the information how to get ST2 recognize Spacemonkey ... :(
  2. MatteKarla
    MatteKarla Member Gold Contributor
    20Coins
    You maybe haven't done everything correctly? Have you followed the instructions in the PDF? have you selected defaultPacketFormat instead of codemasters extradata3, are you sure you have specified the correct port (believe it's 10001, but you will need to verify it).
  3. sci666
    1,210Coins
    i checked your manual again .. and its not working simtools wont switch to "game running"
    i do all the things in the manual. but its Spacemonkey 1.1.1 today AND its wreckfest 64bit what spacemonkey needs. but ST dont want to go "online" see screenshots[​IMG][​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
  4. sci666
    1,210Coins
    Can somebody please post some Screenshots of working spacemonkey plugin?
  5. Marin
    Marin New Member
    - 50Coins
    Good morning,
    I have simtool v2 is it possible to try your plugin?
    THANKS
  6. MatteKarla
    20Coins
    It only works in SimTools V3. Sorry.
  7. LSDD
    LSDD 5DOF - 5x SCN5 - FREX connector
    Chiptunning
    Paris
    102Coins
    SCN6, 4DOF
    Hi!
    I have Simtool V3 and would like to test it. I used to play Wreckfest with SRS when my rig was 3DOF with spacemonkey plugin.
    153,740Coins
    SimTools V3 is in opeen Beta testing, it is not yet released and these are the plugins currently available, other are being ported as time permits: https://simtools.us/plugin_library/
    SimTools V2 plugins, of which Wreckfest is one, are not compatible with V3.
    You can run V2 and V3 on the same machine with the same license, as long as you don't try and run them at the same time.
  9. LSDD
    Chiptunning
    Paris
    102Coins
    SCN6, 4DOF
    I know that noorbeast. I spent time to understand how simtools works and i setup both v2 and v3. I would prefer to use v3 only of course because it is all in one.
    I was asking to MatteKarla for his homemade plugin. It is a great project if it will run the game by itself and works with v3!
  10. Marin
    Marin New Member
    - 50Coins
    is it possible to have the plugin?
    153,740Coins
  12. Marin
    Marin New Member
    - 50Coins
  13. noorbeast
    153,740Coins
    SimTools v2 plugins are not compatible with v3 and visa versa.
  14. Marin
    Marin New Member
    - 50Coins
    Hello can you share with me the plugin for simtools v3
  15. Marin
    Marin New Member
    - 50Coins
    Hello, I also tried with simtools 2, it starts working but no movement. I launched it in 32 bit dx11, nothing
  16. MatteKarla
    20Coins
    Looks like bugbear has released a new version of Wreckfest, I tried to update the pointers to the new offsets and it appears to be working again with SimTools3.
    I'm not playing wreckfest nowdays, since it doesn't have VR support. hoping Wreckfest2 will have VR.
    https://drive.google.com/drive/folders/16BD6fnRgeu0ymLoeeFvTco1IjpkFDz8Q?usp=sharing
    Drag the plugin to SimTools3 to install it. Lower profile intensity in SimTools to about 15 (by clicking the waves, then adjusting the slider down right).
    Unzip WreckfestReader to a folder, double click the file WreckfestReader.Exe, then it should be just starting the game. (use version 1.0.1)
    You should use Wreckfest 64-bit.
    • Detects game running.
    • Automatically detects and attaches to send telemetry when you start a new race.
    • Works with multiplayer (by figuring out your name the telemetry provider can figure out what index you have and load telemetry for the correct player).
    • Also sends "basic telemetry" to SimHub when using buttkickers (udp port 20777, in format CodeMasters Extra Data 3, use Dirt2 for example)
    There could be a delay before motion starts, since the reader detects race running and then scans memory for telemetry.
    @Marin You can try this
  17. Marin
    Marin New Member
    - 50Coins
    A big THANK YOU THANK YOU it works. See you soon for Wrecfest 2 in VR I hope also have a good day
  18. Garry Samson
    Garry Samson New Member Gold Contributor
    - 55Coins
    Has anyone tested if this plugin still works on Wreckfest 2? Thanks in advance!
  19. MatteKarla
    20Coins
    No, it doesn't work in WF2. However SpaceMonkey plugin should work with WF2. I think he also has some improvements planned.
    I have rewritten WreckfestReader to work with WF2, but it's still work in progress, and currently I don't have much time to cleanup and release it :-( It's hardcoded to use my nick on Steam to detect what player I am etc. If I get time to finish it up I will post here.
    Single player works great, but multiplayer telemetry is having some serious issues :-( Auto detection of player and race in progress works.
    But since I'm using SimHub now instead of SimTools I just send "dirt rally -telemetry". And it should work the same for ST3.
  20. Garry Samson
    - 55Coins
    Thank you! Appreciate all your hard work! Does SpaceMonkey works with Simtools v3? I saw a YouTube post where it was working with Space monkey and Simhub for motion.
