720 degree sim
Discussion in 'DIY Motion Simulator Projects' started by Kevin Kemp, Feb 23, 2024.
  1. Kevin Kemp
    Kevin Kemp New Member
    82Coins
    Hello all,
    Im new here, I’m from Holland and I wanna build my own 720 degree motion rig.
    I’m now in testing fase and have a test setup. I’m using a arduino uno r3 with md20a motor drivers from cytron.
    So what I want is a full 360 for roll a pitch. What do I need for sensors on the motors ? Because nou when I rol the plane the motor keeps rolling.
    And what zo I need for settings in Smc3 and simtools. And what hardware do I need to ad to my test setup ?
    already thanks for the help
    153,926Coins
    +11,156 / 57 / -2
    Can you please provide an example or drawing of what you would like to create and why.
    While continuous rotation may seem a good idea there are technical/cost complexities for questionable motion outcomes in terms of exploiting weaknesses in psychological and physiological processing.
    As @yobuddy explains here if you want your simulator to do 360's, then your going to need hardware that knows how to do 360's. For instance, the smc3 firmware, and most like it, are not setup to do such things.
  3. Kevin Kemp
    82Coins
    This is what I want to build. So I need sim information how can help me with the programs and hardware I need.
  4. harrie
    harrie Member
    coevorden
    221Coins
    Arduino, 4DOF
    hallo en welkom .... i .m also in the setup a 720 degree flight simulator , already did make a 4 dof racing sim motion ... i gone used 220v reductie motors and some freqentie boxes . with a good geardrive , tandwielen en ketting , whas already looking into software for 360 flight sim motion . how do you want to connect the wiring 220v to the rotating ? i did see many solutions , looking for a cheap diy solution ..
  5. harrie
    harrie Member
    coevorden
    221Coins
    Arduino, 4DOF
    there is a guy onto marktplaats.NL selling cheap 220v elektro motor with reductie box and with freqencie box included . -150 euro .also got a cheap adres for heavy gear and chain .
  6. Kevin Kemp
    82Coins
    Hey thanks for your reply. I’m was looking for some worm drive motors and no idea yet for the software I need to use for this. I wanna connect everything via sliprings for data and 220v.
  7. Kevin Kemp
    82Coins
    O yeah I like to have this i was looking for the gears a chains. Send me a dm.
