Showroom 3DOF DC Brush motor actuators
Discussion in 'DIY Motion Simulator Projects' started by m50b20, Feb 22, 2024.
  1. m50b20
    m50b20 Member
    100Coins
    Hi all !
    Trying to build my first moving sim with resources and space i have
    After a long readings and watching youtube i went from moving seat with wiper motors to some 3dof platform
    I'm trying to build silent and smooth-moving thing, with not a lot of travel but with Heave.
    Going actuator conception(not worm-geared)
    Hope i'm on the right way
    Also a haven't too much space for it, only 1 meter width and 2 meters of length
    List of components:
    1. Motors - DC brush motors Dunkermotoren 24v
    2. Ballscrew 1605
    3. PSU MeanWell 320W 18-24V one for each motor
    4. IBT2 - 1 or 2 for each motor
    5. Hall-type potentiometers
    And also a lot of bolts, nuts, lasercut and wires )
    So i'm started....
  2. m50b20
    m50b20 Member
    100Coins
    Two of three brothers are ready
  3. m50b20
    m50b20 Member
    100Coins
    Feedback potentiometer system must look weird, but it works
  4. early_m
    early_m Active Member
    Chelmsford
    820Coins
    Interested to see how your project pans out. Some videos of your actuators in motion would be great to see
  5. m50b20
    m50b20 Member
    100Coins
    Of course i'll make a video, i'm very interested in it myself
    But the actuators cannot work without seat platform - it will broke itself
    Base is ready
  6. m50b20
    m50b20 Member
    100Coins
    Can you tell me the width of your base please ?
    And what do you think about gas struts placing - like this:
    : IMG_20240225_024839.jpg
    Or like this:
  7. early_m
    Chelmsford
    820Coins
    I would place the strut as per your first photo, within the frame. That way all travel will be equal.
    My 3dof frame is approx 1m wide
  8. m50b20
    m50b20 Member
    100Coins
    Keep going...
    Take old trainer to build seatbase of it :grin
    Had to bought U-joints instead of bull-eye - to avoid rotating of ballscrew nut - success, it's stop rotating
  9. m50b20
    m50b20 Member
    100Coins
    Soldered new thick wires to motors
  10. m50b20
    m50b20 Member
    100Coins
    Installed u-joints on every corner, add length to rear beam (ab. 8 cm) to move COG a little backwards
    I'm the worst welder in the world )))
  11. early_m
    Chelmsford
    820Coins
    I take it the pot will be attached to the wheel that travels up and down?
    What is the torque and rpm of the motors?
  12. m50b20
    m50b20 Member
    100Coins
    Yes, you are right, it's already installed, but i removed them till i'm finish welding and cutting
    Not the best decision, but i like it for hall sensor pots
    0.6 nm, 2900 rpm
  13. early_m
    Chelmsford
    820Coins
    Is there a gearbox on them?
    Do you know what output torque you achieve with the ball screws?
  14. m50b20
    m50b20 Member
    100Coins
    No any gearbox. There is a same amount of torque on the ballscrew shaft because its directly connected to the motor shaft. One motor installed on the corner lift me up with ease without gas strut and really quick. But real talk is what it will be with quick direction change. Let's wait for me to install electronics and start smc3
  15. early_m
    Chelmsford
    820Coins
    Looking forward to seeing a video of performance
  16. m50b20
    m50b20 Member
    100Coins
    Hope it will not fall apart after five minutes :popcorn
    • Funny Funny x 2
  17. m50b20
    m50b20 Member
    100Coins
    I much more like the concept of linear potentiometer, maybe i will buy it for testing later, there are some on Ali
  18. early_m
    Chelmsford
    820Coins
    Could be a g
    Could be a good idea, although a hall effect pot without any end stops would offer safety from breaking if over extending
  19. m50b20
    m50b20 Member
    100Coins
    This video is 2 days ago, ballscrew without any grease, acting only in up direction, falling down by gravity )
    I'm 95 kg
  20. early_m
    Chelmsford
    820Coins
    Looks great, plenty fast enough
