Showroom 3DOF DC Brush motor actuators
Discussion in 'DIY Motion Simulator Projects' started by m50b20, Feb 22, 2024.
  1. m50b20
    m50b20 Member
    122Coins
    It's alive !!!
    And working not bad
    Put my legs to add load )
  2. m50b20
    m50b20 Member
    122Coins
    Manual mode
    Is it fast enough?
    Sounds too noisy in video, in real live it sounds different
    153,920Coins
    +11,156 / 57 / -2
    Your rig certainly looks fast enough :thumbs
  4. m50b20
    m50b20 Member
    122Coins
    Looks like T800 without flesh :)
  5. m50b20
    m50b20 Member
    122Coins
    @noorbeast and @early_m or someone who knowd, do i need two Arduino to run three motors or single is enough? Or single is enough but two is better?
    I can't understand
  6. early_m
    early_m Active Member
    Chelmsford
    839Coins
    Looks great to me!
  7. early_m
    Chelmsford
    839Coins
    While you can use 3, I find it easier to use 2 so that I can place them closer to my driver
  8. m50b20
    m50b20 Member
    122Coins
    So, there is a problem - everything is fine and smooth in SMC3 utility, but in SimTools something goes wrong:
    1. After launching Simtools all motors going lower simultaneously - about 40% of all height
    2. In Output Testing everything works, but jerking a lot
    153,920Coins
    +11,156 / 57 / -2
  10. m50b20
    m50b20 Member
    122Coins
    Yes
    Settings SMC3:
    Settings SimTools:
    Video SMC3
    Video SimTools:
    153,920Coins
    +11,156 / 57 / -2
  12. m50b20
    m50b20 Member
    122Coins
    For language - Simtools and LiveForSpeed works with motion, but jerking.
    I will try to change language, ok )
  13. m50b20
    m50b20 Member
    122Coins
  14. m50b20
    m50b20 Member
    122Coins
    New question - there is a very little movements in LFS - is it ok ? About 10-15% of rig's ability
    In Output Testing it works for whole range
    Update: in rally-cross it is ok ))))
    153,920Coins
    +11,156 / 57 / -2
    Axis allocation is only part of refining a motion profile, you also need to first capture then refine the Tuning Center values, see the motion profile tuning tips in the FAQs, and take note of first doing one axis at a a time, then combine and refine: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  16. m50b20
    m50b20 Member
    122Coins
    Thanks, i will try
    After language change it works like a charm, God bless you ))
    153,920Coins
    +11,156 / 57 / -2
    That has been a pesky Windows rather than SimTools bug, that only seems to affect some computers in specific circumstances, and it has been difficult to pin down why, but at least it is a simple fix and I very much look forward to seeing your rig in action.
  18. early_m
    Chelmsford
    839Coins
  19. m50b20
    m50b20 Member
    122Coins
  20. m50b20
    m50b20 Member
    122Coins
    Waiting for DIY license....
