Question Problem with SMC3 Arduino
Discussion in 'New users start here - FAQ' started by spyrates, Feb 29, 2024.
  1. spyrates
    spyrates New Member
    77Coins
    Hello friends, I have a problem with smc3, I can't get the green line, follow the blue line, please fix it.
    151,504Coins
    +11,041 / 56 / -2
    Can you please detail the control boards being used, what motors, confirm the com port is correctly set, and please post pictures of all of your SMC3 settings.
  3. spyrates
    spyrates New Member
    77Coins
    [QUOTE="noorbeast, post: 246511, member: 10786
    QUOTE ]
    Can you please detail the control boards being used, what motors, confirm the com port is correctly set, and please post pictures of all of your SMC3 settings.[/QUOTE]
  4. spyrates
    spyrates New Member
    77Coins
    b
  5. spyrates
    spyrates New Member
    77Coins
      10.2 KB
      147
  6. spyrates
    spyrates New Member
    77Coins
      185 KB
      365
      185 KB
      139
  7. spyrates
    spyrates New Member
    77Coins
    I have a 24 volt linear actuator and I have attached the hall sensor to it but I can't get the green line of the hall sensor to follow the blue one and it doesn't move at all. The truth is I don't know how to configure it to follow it, and I'm lost.
  8. spyrates
    spyrates New Member
    77Coins
  9. spyrates
    spyrates New Member
    77Coins
    I don't know if the udp port 20017 port needs to be put somewhere, thanks friend for helping me
  10. spyrates
    spyrates New Member
    77Coins
    151,504Coins
    +11,041 / 56 / -2
    Has the SMC3 code been edited to MODE 2 for the IBT2s: https://www.xsimulator.net/community/threads/problems-with-my-simulator.15382/#post-207320
    Can you please confirm the Com Port is correct, you can do so in Device Manager.
    This is the official wiring guide for IBT2s:
    Have you checked the functioning of the IBT2s with a multi-meter?
    I am not sure how you got the settings you have with no feedback, these are the SMC3 setup steps: https://www.xsimulator.net/communit...3dof-motor-driver-and-windows-utilities.4957/
    I strongly recommend you follow the steps below if this is the first time you are using SMC3 with your simulator to reduce the risk of damaging anything.
    8. Set Kp to about 400
  12. spyrates
    spyrates New Member
    77Coins
    Has the SMC3 code been edited to MODE 2 for the IBT2?
    Yeah
  13. spyrates
    spyrates New Member
    77Coins
    Have you checked the operation of the IBT2 with a multimeter?
    I think this may be the problem, how do I check it with a multimeter?
    I do the test that you told me and it doesn't move
  14. spyrates
    spyrates New Member
    77Coins
    I changed the IBT2 for another one, it moved while doing the test and it stopped
  15. spyrates
    spyrates New Member
    77Coins
    Then the source stopped and I removed it and the source started working again but when I plugged it in the source stops
  16. noorbeast
    151,504Coins
    +11,041 / 56 / -2
  17. spyrates
    spyrates New Member
    77Coins
    The two IBT2's have been screwed up doing the tests and also a power supply could be the positive and negative of the hall sensor, do they have to go the other way around?
  18. noorbeast
    151,504Coins
    +11,041 / 56 / -2
    The Hall sensor should be marked for wiring.
    As mentioned earlier, this is the wiring from the SMC3 thread for IBT2s, though some members have also reported quality issues with the IBT2s:
  19. Serik
    Serik New Member Gold Contributor
    - 186Coins
    Perhaps you set high settings in the utility and a strong current surge occurred.
