Question wiring belt tension motor 5 wire ?
Discussion in 'Electronic and hardware generally' started by harrie, Mar 11, 2024.
  1. harrie
    harrie Member
    coevorden
    221Coins
    Arduino, 4DOF
    got this motor from a project , question is , it got 5 wires . red/black for power . but wherefore are the yellow /blue/ black wire ? hall sensors ? if so could i use these instead of a potention meter ? someone know this wiring ? did google but did not find any these types motors with 5 wires ?
    153,938Coins
    +11,158 / 57 / -2
    Possibly high/low speed, but find the full specifications and that should tell you.
  3. harrie
    harrie Member
    coevorden
    221Coins
    Arduino, 4DOF
    that is just the problem, no spec can i find .. nothing . i think 2 things i could do . open up the motor en see wherefore the wiring is ore just use the power wiring and hook it up to potentie meter and use it this way , without using the 3 extra wiring ?
    153,938Coins
    +11,158 / 57 / -2
    Power it up and see if it runs OK, if not then open it up and check the internal wiring.
