Question PS5 / Grand Turismo Proxy Help
Discussion in 'SimTools DIY Version' started by miketunes, Mar 18, 2024.
  1. miketunes
    miketunes Member
    254Coins
  2. ProjectF1
    ProjectF1 Member
    Electrician
    302Coins
    AC motor, Arduino, 4DOF
    good evening, you need to retrieve the IP address in the menu of your PS5 (see photos) and on your PC (in order invitations)
  3. miketunes
    miketunes Member
    254Coins
    I do have the ip, but I can't seem to clone the repo to start it working.
  4. ProjectF1
    ProjectF1 Member
    Electrician
    302Coins
    are you using Simtools v3?
  5. miketunes
    miketunes Member
    254Coins
    yes
  6. miketunes
    miketunes Member
    254Coins
    Any suggestions to try, anyone else get this working?
    152,003Coins
    +11,061 / 56 / -2
  8. Rodrigomarcos1978
    Rodrigomarcos1978 New Member
    Brasil
    97Coins
    "Hello! If you'd like to try it out, I've created an installer for the GT7 Proxy that simplifies a few things:
    The installer already provides a shortcut to the GT7 Proxy file on the desktop.
    If you're using Windows 10, after installing this version and clicking on the desktop shortcut, the system will display telemetry data correctly on the screen. Previously, there were jumbled numbers running quickly.
    Whenever you open the program through the desktop shortcut, the system will ask if you want to modify the PlayStation's IP. If you respond Yes within 5 seconds, you can change the IP and it will automatically save the new one, so you won't need to manually edit the shortcut as before."
    https://drive.google.com/drive/folders/1mad-Q0gUCPEaBHbQnmBIeuTd5BOiWB26?usp=sharing
    I also have a video but it is in Portuguese BR:
