My DD project
Discussion in 'Direct Drive Wheels' started by Bonstinger, Aug 3, 2023.
  1. Bonstinger
    Bonstinger New Member
    25Coins
    DC motor, Arduino
    Hi everyone this is my project with a 850W MY1020 motor. I´ll start with one BTS7960 H bridge and a 12V 10 Amp power supply and then when everything works properly upgrade to 3 H bridges and probably a 1000w power supply. The encoder is belt-driven because i don´t have the tools to do a proper direct drive to the motor shaft but i have a 3D printer so i can easy do it that way. will be driven by a gt2 belt with 2:1 gear ratio to duplicate the ppr of the encoder.
    i let you some renders of the project and i wanna know what you think.
    Thanks and sorry for my English is not my native language.
      552 KB
      497
      295 KB
      481
      557.6 KB
      503
      264.7 KB
      473
      480.1 KB
      475
  2. Harman singh
    Harman singh New Member
    120Coins
    Brother I like your project, I also have a same way of building my own.
    Where have you reached now, is your project complete
    If complete can you show us
    (Sorry for my English, I hop you understand what I wanna ask)
    153,824Coins
    +11,150 / 57 / -2
    @Bonstinger has not been around since mid last year, so you may have to be patient for a response.
  4. Harman singh
    120Coins
    can you tell me which is the latest stable firmware for belt drive ffb steering wheel with arduino leonaro or
    stm32f4 with bts7960 and other software requirement need for ffb to work.
    I had read most of the forum and having complexity understand working of different software like EMC, Aiwave, mmos etc.
    please help me through it
    153,824Coins
    +11,150 / 57 / -2
    I would suggest you check the latest related project builds in the relevant thread sections:
    https://www.xsimulator.net/community/forums/diy-peripherals.32/
    https://www.xsimulator.net/community/forums/direct-drive-wheels.175/
    Then check the profile of knowledgeable members to see when they were last active, so you know they are still around.
    You can then ask a question here on your build thread of a specific member with direct experience, by using the @ symbol with their user name, that way they will receive an automatic notification of that question: https://www.xsimulator.net/community/faq/tag-a-member.73/
  6. Harman singh
    120Coins
    Thank you for helping me
  7. Quang Minh
    Quang Minh New Member
    24Coins
    Your motor has high power but low torque. If you replace it with a power steering motor, the torque will be higher.
