Dof reality P3 gear motors replacement
Discussion in 'Commercial Simulators and Peripherie' started by Alim, Apr 12, 2024.
  1. Alim
    Alim New Member
    22Coins
    3DOF, DC motor
    I want replace the P3 old original motor to new and improved one but not sure what to choose from. Which one do U guys recommend me buying? Do know anything that will perform as close to an actuator or a dbox. I still have the dof reality control box aswell and the original steel frame. Do you reckon it would still work if you just removed the motor and slap a new one? I got some pictures below
    153,830Coins
    +11,151 / 57 / -2
    Can I ask what is wrong with the motors on it now?
    And can you please move the cable and take a clear picture of the spec sticker on the top of the motor.
  3. Alim
    Alim New Member
    22Coins
    3DOF, DC motor
    Motors works but probably lil bit slower now than it was.
    153,830Coins
    +11,151 / 57 / -2
    Have you considered pulling the motors apart and checking the brushes, which do wear over time?
  5. Radioproffi
    Lviv
    1,677Coins
    you can upgrade your front worm gearbox to SFU-gears, this will be a decent improvement for relatively little money
