Question Thanos+double TL+Surge
Discussion in 'DIY Motion Simulator Projects' started by simone maggioli, May 17, 2024.
  1. simone maggioli
    simone maggioli New Member Gold Contributor
    56Coins
    4DOF
    Hi everyone. I apologize if I'm in the wrong section, but I tried searching and couldn't find anything.
    I recently mounted my station (6DOF), and tried the configuration on simtools (7 AMC AASD15A with @Thanos.) The problem is that when I run the test output it doesn't detect the Surge. Is there a guide for my 7 servos? Thanks.
    150,037Coins
    +10,993 / 54 / -2
  3. simone maggioli
    56Coins
    4DOF
    You mean this?
    150,037Coins
    +10,993 / 54 / -2
    Did you capture the Max/Min values in the Tuning Center and can you please post a picture of it while the game is running.
  5. simone maggioli
    56Coins
    4DOF
    No i don’t. I simply try the outputmode. When i move the different parameters all the actuators work except the Surge mode.
    150,037Coins
    +10,993 / 54 / -2
    Output Testing uses the Default profile in Axis Assignments, so can you please post a picture of that.
  7. simone maggioli
    56Coins
    4DOF
    It’s the same like the others pictures
  8. simone maggioli
    56Coins
    4DOF
  9. simone maggioli
    56Coins
    4DOF
  10. simone maggioli
    56Coins
    4DOF
    Another things. I wiring the actuators like this:
    RL port1, FL port2, FR port3, RR port4, TL rear port5, Surge port6, TL front port7
  11. simone maggioli
    56Coins
    4DOF
    I configured the 6 axis, where i can find the 7th? Because miss.
    150,037Coins
    +10,993 / 54 / -2
    @Thanos is best placed to answer questions about the scope an configuration of his controller.
  13. Thanos
    Electronics Engineer
    2,798Coins
    I think in simtools is the axis1b (since first 6 actuators are on slot a)
  14. simone maggioli
    56Coins
    4DOF
    Hi everyone.
    I have these 2 problems:
    1) When I turn on the actuators and then the PC the TL rear actuator automatically extends to the maximum, and when I turn off the PC it does not return to its initial position.
    2) The FTL actuator does not move. If I activate it directly from the AASD it works.
