IBT-2 H Bridge no 24v output
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Richard Eaton, Jun 19, 2024.
  1. Richard Eaton
    Richard Eaton Member
    241Coins
    I have the strangest issue and I can't work out the issue, my IBT-2 bridges don't have an output voltage, there is 24v going in but nothing coming out, these are new bridges.....Should I get a voltage with no connections to the Uno board? Although I have also connected up and still no output.
    153,914Coins
    +11,156 / 57 / -2
    Are you using SMC3 set to Mode 2, and if so can you please post pictures of all your settings.
    As an aside, some members have reported issues running the IBT2s at 24v and have more success lowering the voltage a little.
  3. Richard Eaton
    241Coins
    Hi, yes SMC is set to Mode 2, I've been running this setup at 24v for a while previously with no issues, I'm stumped tbh with what could be wrong, maybe it's the Uno that has the issue.
    If you are not connected to the Uno would you still see 24v output from the IBT or does it need to be connected for the throughput to work?
    153,914Coins
    +11,156 / 57 / -2
    It should be connected and when you run say the Sine test in SMC3 the output voltage will vary to drive to the curve, hence why pictures are useful.
    With the Arduino and IBT2 hooked up turning the pot should result in measurable current output.
  5. Richard Eaton
    241Coins
    Firstly remember I have had my rig running for over 6 months with no issues.
    I had a mechanical issue with the CV joint and had to modify the setup, however when I tried to get it going again it appeared dead.......
    So this is where I am now:
    2 x new 24v 15amp PSU's
    2 x new IBT-2
    1 x new Uno3
    Still the same issues
    I have 24v coming from the PSU into the IBT-2 but nothing coming out to power the motor
    If I run SM3Util and turn the POTS manually then as expected my wavelength changes depending which way a turn the POT.
    I'm stumped to understand what is stopping the 24v passing through the IBT.
    I am running SM3 v1.0 and have set Mode 2
    Thanks for any help with this.....
    153,914Coins
    +11,156 / 57 / -2
    If there is no power out of a control board it is likely faulty, if everything else is set up properly..
  7. Richard Eaton
    241Coins
    Hi, as you mentioned when I turn the pot it does increase the voltage, I'm testing this with a 24v fan and the fan kicks in. However it doesn't drive the motors. If I connect the motors directly to the 24v from the PSU they spin fine.
    So I have voltage, just wondering if current is the issue not enough output to move the motors.
    153,914Coins
    +11,156 / 57 / -2
    Have you checked the output with a multi-meter, so you are actually measuring what the output is?
  9. Richard Eaton
    241Coins
    Right, so found I had a dry solder, re soldered and motors up and running, however next problem, when powered on the motor just turns and hits it's limits, set the pot position, set the motor position but SM3 tool hasn't got full control.
    153,914Coins
    +11,156 / 57 / -2
    I am having trouble reading those images, they are poor quality.
    Set Fpwm to 25.
    Initially set Clip Input and Max Limits to 200 until everything else is working as expected, then refine their settings.
    Worst case do the setup steps from scratch:
    Initial Setup
    8. Set Kp to about 400
  11. Richard Eaton
    241Coins
    Hi, please see YouTube video link, I have rewired, confirmed Comms, checked green line moves when turning Pot but as you will see no control just wants to spin, could the pots be duff?
  12. Richard Eaton
    241Coins
    I have now run out of ideas.
    New IBT-2
    New Uno R3
    Mode 2 {Also tried Mode 1 out of curiosity, same result)
    Turning the PID works, the green line moves
    If I remove the PID wire the motor just continuously rotates, which I believe is normal
    Set the PID to center
    Power on the motor, it tries to rotate still as if the PID wire wasn't attached, but hits cutoff limits and stops.
    Swapped over wiring so Motor 1 becomes Motor 2, same issue.
    Any ideas welcome.....I am stumped :-(
  13. noorbeast
    153,914Coins
    +11,156 / 57 / -2
    What are your current settings and please post pictures.
    At what step in the official set up ptocedures fails?
  14. Richard Eaton
    241Coins
    Hi, I posted a link to a YouTube video above, hopefully it works, happy to post more detail if you need it.
  15. Richard Eaton
    241Coins
  16. Richard Eaton
    241Coins
    Anyone able to make any suggestions...Would could be wrong......
    153,914Coins
    +11,156 / 57 / -2
    Disconnect the power to the motor pot and check the pot is centred when on.
  18. Richard Eaton
    241Coins
    Hi, so if I center the pot then close down SMC3 and disconnect the Uno, when the Uno is powered back on and SMC3 started the green line stays centered, the issue occurs when the IBT-2 is connected. Tried several IBT with same result.
  19. Richard Eaton
    241Coins
    Have setup both motors, and both are suffering the same issue, this seems to point to an issue with the Uno as that's the only part that's shared between both motors.
  20. Richard Eaton
    241Coins
    This is my own wiring diagram that was updated as I wired the uno/ibt.pot.
    Still doesn't work, as soon as the PWM wires are connected the IBT gets red hot instantly.
    New Uno, new pots, newish IBT, wondering if they are now cooked and I need new ones
