help with SimXperience Accumotion controller working with Simtools
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by rocketfire302, Jun 20, 2024.
  1. rocketfire302
    rocketfire302 Member
    134Coins
    SCN5, SimAxe
    Hi, i have a SimXperience accumotion controller that i'd like to control with Simtool to get more control over the motors. The board has four connectors outputs, however it only came with 2 motors which you plug in connector 1 and 2. if i can get more out of the board and run 2 more motors from connector 3 and 4 that would be nice. however just getting SimTools to work with the controller on the two motors is good enough.
    right now there is very limited control over the motors and as a result the profile's they setup do not rally match Flight characteristic. not shocking given they are mainly into racing.
    So i'd like to create my own custom experience effect
    where is what i tried.
    -> i used a fee version of Simtool to setup an interface
    -> i picked port 4 which is the only one shown available to pick from.
    -> Asigned Axis ID Axis1A , set speed and accelerator
    -> saved then tried testing
    nothing happens so i'm not sure what is going on.
    153,716Coins
  3. rocketfire302
    134Coins
    SCN5, SimAxe
    well after a good read, i still can't get it to work. maybe its down to the actuator # being off.
    however the link in the post don't work anymore to reprogram the actuators
    any other idea?
    153,716Coins
    I don't have the hardware to check, but try the software download page: https://miraiintertech.com/download-final/
  5. rocketfire302
    134Coins
    SCN5, SimAxe
    thank you i'll take a look at that this weekend. Dumb question but if i am able to change the Id, does that mean i just #@$%#$ up being able to use the SimXperience software. meaning is there no going back?
    153,716Coins
    An ID can always be changed back, just take note of whatever is the current configuration.
  7. rocketfire302
    134Coins
    SCN5, SimAxe
    thanks,
    I'll take a look at this further this weekend. on a different note, looking at the motors for this they look nothing like the SCN type stepper. the encoder on the back is round and there is a gearbox on the front. i'm wondering if these might be a different Motor for the Gbelt instead and maybe that's my problem. Have you heard of SimXperience only using SCN or is there a possibility for a then to have used a different motor?
    153,716Coins
    Can you please post pictures.
  9. rocketfire302
    134Coins
    SCN5, SimAxe
    here is a picture of the stepper
