Help with software/programming
Discussion in 'Commercial Simulators and Peripherie' started by Gard Haug-Hansen, Jun 23, 2024.
  1. Gard Haug-Hansen
    Gard Haug-Hansen New Member
    76Coins
    Hello all.
    I have a VR-egg thats not currently used and I would like to program new movement files that fits som 3d/360 movies or get it to move in a simulator like msfs.
    The platform allrede have all hardware but I have no idea how the software work. Would this be possible?
    All help is much appreciated.
    152,718Coins
    +11,092 / 56 / -2
    Most of these arcade rigs use proprietary systems, so in many cases the easiest way to get control of them is to ditch and replace that, but of course that is often expensive.
    Years ago @Thanos provided the means to jailbreak some of these arcade rigs, but no longer does so.
  3. Gard Haug-Hansen
    76Coins
    Thank you for replay. Its seems possible to access all computors inside to add movies and edit the code. I havent been able to see the movement files though
  4. Gard Haug-Hansen
    76Coins
    How does simtools work, what is between the software and the actuator? I guess a controller but does the controller need to be a spesific supported type?
    Maybe simtools will work for me, but im no quite sure how the software will find the actuators
    152,718Coins
    +11,092 / 56 / -2
    Please see the FAQs for SimTools manual and other details: https://www.xsimulator.net/community/faq/simtools-settings-tips-and-tricks.18/category
    SimTools needs to be able to 'communicate' with control hardware and code, in other words get information in a known format. That is the issue with proprietary systems, they don't release details on how to communicate.
  6. Gard Haug-Hansen
    76Coins
    I think I found a solution to this. Someone has allready made this work.
