FlyPT Mover 3.5.3
  1. Attyla.pl
    Attyla.pl Active Member
    Polska
    1,101Coins
    I have a huge request to the creator of FlyPTmover :), could he please look into the issue of limiting platform movements when receiving high pitch and roll data from DCS if we use "roll speed" and "pitch speed" to control motion platform movements.
    I looked through some ".mover" configuration files I found on the internet but most are related to flying in MSFS 2020 where this situation does not occur, while I only fly in DCS which has its own specificity of situations occurring in it and generated values of "roll speed" and "pitch speed" . In addition, I recently spoke with a MotionXP 6DOF user who confirmed that at the time of shooting down when the aircraft rapidly changes its position in space he has to turn off the movement of his 6DOF to avoid violent movements. Attempts to limit with CROP, MAXCROP, MINCROP , SPIKE filters do not yield good results.
    Yesterday, looking for a solution, I came across a plugin for asseto corsa that simply disables data transfer after exceeding a certain value ( in this case G force) https://www.overtake.gg/downloads/flypt-source-changer.62133/
    The question is whether it is possible to add such a filter in which by selecting a value you could turn off telemetry processing until the value returns to normal?
    It could also be that I just don't know how to use filters :(, that's why I attach my .mover profile and recorded fragment of flight with high values of "roll speed" and "pitch speed" maybe someone smarter than me :) will find some time to watch it and possibly correct my obvious mistakes .
    And one auxiliary question, what could be the reason for the fact that with the set limit of 4 degrees of arm movement in reality the arms rotate in the range of about 45 degrees ? it would seem that after entering 2DOF geometry according to reality the range of motion should be mapped 1:1 ?
  2. arminglf
    arminglf New Member
    130Coins
    Is there any way to make EA WRC work while we wait for the new release? thanks
  3. Nick Clements
    Nick Clements Member
    95Coins
    2DOF, 3DOF, DC motor, SCN5, Arduino, Motion platform
    What I really need is help on adding a rotating actuator to my existing 2dof setup in Flyptmover to have as yaw/traction loss?
    Do I just add another Rig alongside my 2dof one? If I select 3dof with rotating actuator I get
    My rig does notlook anything like this?? I have two motors on the front and one on the back for yaw.
    Do i just add a single rotating actuator to exising setup
    If so how do you configure it for Yaw???
    Very confusing??
  4. pmvcda
    15,372Coins
    Please try this: (I could not test...)
    In the folder \Documents\My Games\WRC\telemetry\udp
    Create a file named FlyPTMover353.json anfd put the following text inside:
    Code:
        "versions":
            "schema": 1,
            "data": 3
        "id": "FlyPTMover",
        "header":
            "channels": []
        "packets": [
                "id": "session_update",
                "channels": [
                    "game_total_time",
                    "vehicle_position_x",
                    "vehicle_position_y",
                    "vehicle_position_z",
                    "vehicle_speed",
                    "vehicle_velocity_x",
                    "vehicle_velocity_y",
                    "vehicle_velocity_z",
                    "vehicle_left_direction_x",
                    "vehicle_left_direction_y",
                    "vehicle_left_direction_z",
                    "vehicle_forward_direction_x",
                    "vehicle_forward_direction_y",
                    "vehicle_forward_direction_z",
                    "vehicle_hub_position_bl",
                    "vehicle_hub_position_br",
                    "vehicle_hub_position_fl",
                    "vehicle_hub_position_fr",
                    "vehicle_hub_velocity_bl",
                    "vehicle_hub_velocity_br",
                    "vehicle_hub_velocity_fl",
                    "vehicle_hub_velocity_fr",
                    "vehicle_cp_forward_speed_bl",
                    "vehicle_cp_forward_speed_br",
                    "vehicle_cp_forward_speed_fl",
                    "vehicle_cp_forward_speed_fr",
                    "vehicle_throttle",
                    "vehicle_steering",
                    "vehicle_brake",
                    "vehicle_clutch",
                    "vehicle_gear_index",
                    "vehicle_acceleration_x",
                    "vehicle_acceleration_y",
                    "vehicle_acceleration_z",
                    "vehicle_engine_rpm_current",
                    "vehicle_brake_temperature_bl",
                    "vehicle_brake_temperature_br",
                    "vehicle_brake_temperature_fl",
                    "vehicle_brake_temperature_fr",
    Now go to the folder \Documents\My Games\WRC\telemetry
    and open the file Config.json
    Add the following to the file:
    Code:
                    "structure": "FlyPTMover353",
                    "packet": "session_update",
                    "ip": "127.0.0.1",
                    "port": 20777,
                    "frequencyHz": -1,
                    "bEnabled": true
    Attention!!!, you are adding this inside the packets, it will be something like this:
    Code:
            "packets": [
                    "ip": "127.0.0.1",
                    "port": 20777,
                    "frequencyHz": -1,
                    "bEnabled": true
                    "structure": "wrc",
                    "ip": "127.0.0.1",
                    "port": 20777,
                    "frequencyHz": -1,
                    "bEnabled": false
                    "structure": "wrc_experimental",
                    "packet": "session_start",
                    "ip": "127.0.0.1",
                    "port": 20778,
                    "frequencyHz": 0,
                    "bEnabled": false
    Try and give me some feedback.
  5. pmvcda
    15,372Coins
    Can you post a picture of the rig?
    One of the solutions is to add a direct just for traction. If you are using VR, you loose compensation by using directs
  6. arminglf
    arminglf New Member
    130Coins
    Thanks, I didn't see this reply I'll try tonight. And what source do I choose? sorry still learning
  7. pmvcda
    15,372Coins
    Dirt rally 2
  8. Zeeflyboy
    Zeeflyboy New Member
    125Coins
    @pmvcda any chance we could get a source added for KayakVR: Mirage? They added telemetry in the latest update apparently.
    happy to buy you the game if you don’t already have it
  9. Avee
    Avee Virtual Pilot
    1,155Coins
  10. Zeeflyboy
    125Coins
  11. Avee
    Avee Virtual Pilot
    1,155Coins
    It's a UDP protocol. Haven't looked into the technicalities, and don't have KayakVR yet. But you could probably just find out the port it is on and then just read what it puts out. Don't think there will be a problem at all.
  12. pmvcda
    15,372Coins
    I'm going to add it. I also sent them a reqiest to have telemetry.
    Don't have the game, but I will get it.
  13. Zeeflyboy
    125Coins
    Can I buy it for you as a donation?
  14. pmvcda
    15,372Coins
    Yes, would be helpful. :thumbs
  15. Avee
    Avee Virtual Pilot
    1,155Coins
    From what I saw on the steampowered forums, their support knows no more than that they have included an unreal telemetry library. They don't seem to know what the output exactly is. If you have already implemented some other unreal game, chances are that it is exactly the same.
  16. Avee
    Avee Virtual Pilot
    1,155Coins
    Looks like the KayakVR telemetry library is communicating with SRS using their API. There is a description of the data format here https://gitlab.com/simracingstudio/srsapi
    Code:
    # definition of the constants
    SRS_COMPUTER_IP = 'localhost'  # to broadcast to all computers in the network use '0.0.0.0'
    SRS_COMPUTER_PORT = 33001  # this port can be changed on the config.ini of srs app
    PACKET_HEADER = str.encode('api')  # constant to identify the package
    API_VERSION = 102  # constant of the current version of the api
    # defition of the Telemetry Class
    class TelemetryPacket(Structure):
        _fields_ = [('api_mode', c_char * 3),  # 'api' constant to identify packet
                    ('version', c_uint),  # version value = 102
                    ('game', c_char * 50),  # Game name for example Project Cars 2
                    ('vehicle_name', c_char * 50),  # car, boar or aircraft name
                    ('location', c_char * 50),  # track name, location, airport, etc
                    ('speed', c_float),  # float
                    ('rpm', c_float),  # float
                    ('max_rpm', c_float),  # float
                    ('gear', c_int),  # -1 = revere 0=Neutral 1 to 9=gears
                    ('pitch', c_float),  # in degrees -180 to +180
                    ('roll', c_float),  # in degrees -180 to +180
                    ('yaw', c_float),  # in degrees -180 to +180
                    ('lateral_velocity', c_float),  # in float between -2 to 2 used for traction loss
                    ('lateral_acceleration', c_float),  # gforce in float values beteween 0 to 10
                    ('vertical_acceleration', c_float),  # gforce in float values beteween 0 to 10
                    ('longitudinal_acceleration', c_float),  # gforce in float values beteween 0 to 10
                    ('suspension_travel_front_left', c_float),  # in float values -10 to 10
                    ('suspension_travel_front_right', c_float),  # in float values -10 to 10
                    ('suspension_travel_rear_left', c_float),  # in float values -10 to 10
                    ('suspension_travel_rear_right', c_float),  # in float values -10 to 10
                    ('wheel_terrain_front_left', c_uint),  # 0=all others, 1=rumble strip, 2=asphalt
                    ('wheel_terrain_front_right', c_uint),  # 0=all others, 1=rumble strip, 2=asphalt
                    ('wheel_terrain_rear_left', c_uint),  # 0=all others, 1=rumble strip, 2=asphalt
                    ('wheel_terrain_rear_right', c_uint),  # 0=all others, 1=rumble strip, 2=asphalt
  17. arminglf
    arminglf New Member
    130Coins
    Sorry I've been busy so couldn't test properly.
    I tried this just now but I can't seem to make it work. Initially I was getting errors in the log file:
    Code:
    Loaded Telemetry Config.
    Parsing file 'custom1.json'
    Loaded upd packet structure 'custom1'
    Parsing file 'FlyPTMover353.json'
    Packet 'session_update' Channels[2] 'vehicle_position_x' is a duplicate channel id.
    Packet 'session_update' Channels[3] 'vehicle_position_x' is a duplicate channel id.
    Packet 'session_update' Channels[4] 'vehicle_position_x' is a duplicate channel id.
    Packet 'session_update' Channels[39] 'vehicle_brake_temperature_bl' is a duplicate channel id.
    Packet 'session_update' Channels[40] 'vehicle_brake_temperature_bl' is a duplicate channel id.
    Packet 'session_update' Channels[41] 'vehicle_brake_temperature_bl' is a duplicate channel id.
    Packet 'session_update' Channels[42] 'vehicle_brake_temperature_bl' is a duplicate channel id.
    Packet 'session_update' Channels[43] 'vehicle_brake_temperature_bl' is a duplicate channel id.
    Packet 'session_update' Channels[44] 'vehicle_brake_temperature_bl' is a duplicate channel id.
    Packet 'session_update' Channels[45] 'vehicle_brake_temperature_bl' is a duplicate channel id.
    Packet 'session_update' Channels[46] 'vehicle_brake_temperature_bl' is a duplicate channel id.
    Packet 'session_update' Channels[47] 'vehicle_brake_temperature_bl' is a duplicate channel id.
    Packet 'session_update' Channels[48] 'vehicle_brake_temperature_bl' is a duplicate channel id.
    Packet 'session_update' Channels[49] 'vehicle_brake_temperature_bl' is a duplicate channel id.
    Packet 'session_update' Channels[50] 'vehicle_brake_temperature_bl' is a duplicate channel id.
    Packet 'session_update' Channels[51] 'vehicle_brake_temperature_bl' is a duplicate channel id.
    Packet 'session_update' Channels[55] 'vehicle_brake_temperature_fr' is a duplicate channel id.
    Packet 'session_update' Channels[56] 'vehicle_brake_temperature_fr' is a duplicate channel id.
    Packet 'session_update' Channels[57] 'vehicle_brake_temperature_fr' is a duplicate channel id.
    Packet 'session_update' Channels[58] 'vehicle_brake_temperature_fr' is a duplicate channel id.
    Packet 'session_update' Channels[59] 'vehicle_brake_temperature_fr' is a duplicate channel id.
    Packet 'session_update' Channels[60] 'vehicle_brake_temperature_fr' is a duplicate channel id.
    Packet 'session_update' Channels[61] 'vehicle_brake_temperature_fr' is a duplicate channel id.
    Failed to validate Packets[0].
    Ignored upd packet structure file 'FlyPTMover353.json', failed to validate file.
    So I deleted all the duplicated channels and tried again with this code:
    Code:
        "versions":
            "schema": 1,
            "data": 3
        "id": "FlyPTMover",
        "header":
            "channels": []
        "packets": [
                "channels": [
                    "game_total_time",
                    "vehicle_speed",
                    "vehicle_throttle",
                    "vehicle_steering",
                    "vehicle_brake",
                    "vehicle_clutch",
    After this I get the below:
    Code:
    Loaded upd packet structure 'flyptmover'
    However when I'm in the game FlyPT is not getting any telemetry.
    Not sure if I'm missing something?
  18. pmvcda
    15,372Coins
    Ok, I'm looking at it...
    Vars have different types than what I expected, I have to do a new one. Let me try.
  19. pmvcda
    15,372Coins
    @arminglf ,
    Ok, it will not work... Sorry.
    The following works, but...
    Code:
        "versions":
            "schema": 1,
            "data": 3
        "id": "FlyPTMover353",
        "header":
            "channels": []
        "packets": [
                "channels": [
                    "game_total_time",
                    "game_frame_count",
                    "game_delta_time",
                    "stage_progress",
                    "vehicle_speed",
                    "vehicle_throttle",
                    "vehicle_steering",
                    "vehicle_brake",
                    "vehicle_clutch",
                    "vehicle_gear_index_neutral",
                    "vehicle_gear_index_reverse",
                    "vehicle_gear_maximum",
                    "vehicle_handbrake",
                    "stage_current_time",
                    "stage_current_distance",
                    "vehicle_engine_rpm_idle",
                    "shiftlights_fraction",
                    "shiftlights_rpm_start",
                    "shiftlights_rpm_end",
                    "vehicle_transmission_speed",
                    "vehicle_up_direction_x",
                    "vehicle_up_direction_y",
                    "vehicle_up_direction_z",
                    "stage_previous_split_time",
    In WRC speeds and acclerations are relative to car and in DirtRally they are relative to the world, so what happens is that those values are converted... Sorry, like I said I could not test at the time.
    Also, the selected gera is a byte in WRC and a float in Dirt so values are wrong
  20. Marco Annunziata
    847Coins
    Thank you Pedro, do you advise using this method, or better to wait for the new release?
