Question Any possibility to reduce the small movements?
Discussion in 'SimTools DIY Version' started by Tintin Boulsard, Mar 20, 2024.
  1. Tintin Boulsard
    Tintin Boulsard Member
    197Coins
    3DOF, Arduino
    I'm building a motion simulator with linear actuators, using stepper motors. It works very well, but it vibrates a lot because of the "mini" steps : the output is really precise so it sometimes moves of one or two steps and these movements produce a lot of vibrations.
    Is there any way to reduce the "sensibility" or something like that on Simtools?
    Thanks,
    Tintin Boulsard
  2. yobuddy
    51,551Coins
    Yes, Increase the max/min value for the DOF on the tuning page.
    There is also the intensity slider at the bottom right pf the screen.
    But most likely the max/min value for the DOF should be enlarged.
    buzz me if you need some help with this, or not sure what to do.
  3. unpowde
    unpowde New Member
    22Coins
    2DOF, 3DOF, Joyrider, SimforceGT
    As my opinion, adding some smoothing filters can help reduce the sensitivity to small step changes, which should in turn reduce vibrations.
  4. Tintin Boulsard
    197Coins
    3DOF, Arduino
    Thank you so much! It is not perfect but reduced a lot of vibrations.
  5. Tintin Boulsard
    197Coins
    3DOF, Arduino
    That could be a solution but the smoothing filters cause delay in the movements. Thanks anyway
  6. yobuddy
    51,551Coins
    Know that the Smoothing filter in v3 is much better than v2 and will react much faster.
    Take care!
  7. Tintin Boulsard
    197Coins
    3DOF, Arduino
    I'm gonna try that but the problem is coming from my motion simulator, not SimTools. I have to reduce the speed of my steppers to reduce the vibrations so adding smoothing filters adds lot of delay. Maybe I can find a happy medium.
  8. LABORIE Guillaume
    LABORIE Guillaume New Member
    - 0Coins
    Hello Tintin,
    For information, I have the same problem with SCN6 actuators that use also motor steppers. I have tried a lot of settings to reduce the vibrations at the end of a mouvement. Then I had to increase the speed of my actuators and I have captured values in the tuning center. I am on RFactor2. What game do you play?
    See my settings for RFactor at the forum about game plug-in "filtering rfactor2 telemetry"
