Question F1 23 (PS5) and simtools V3
Discussion in 'SimTools DIY Version' started by ProjectF1, Nov 23, 2023.
  1. ProjectF1
    ProjectF1 Member
    Electrician
    304Coins
    AC motor, Arduino, 4DOF
    Hello, I would like some advice on tuning simtools V3 in tuning center. I use the F1 23 game on PlayStation 5, and I captured the min and max values in the tuning center: the movements of the platform are very weak (the connecting rod moves a few degrees...)
    Can someone give me the correct tuning center settings as well as the percentages of the different roll surge pitch movements...? THANKS
  2. yobuddy
    51,524Coins
    Can I have a pic of your sim. and a pic of your axis assignments please?
    Give me an idea of what I'm looking at is all.
    Chat soon!
  3. ProjectF1
    ProjectF1 Member
    Electrician
    304Coins
    hello, thank you for responding to my message, here are the parameters that I set in Simtools, (I deliberately set the high percentages to obtain larger movements...)
  4. yobuddy
    51,524Coins
    It looks like you axis assignments is set to use set one of the max min values.
    But the max/min values you are showing me is for set #2, can I see what set #1 looks like? upload_2023-11-24_14-10-37.png
  5. ProjectF1
    ProjectF1 Member
    Electrician
    304Coins
    Hi "my friend", in fact I hadn't seen that you could select "set 1" in "axis assignment"...
    But I think that the problem of my movements being too weak does not come from this setting...
    THANKS
  6. yobuddy
    51,524Coins
    No problem.
    I would set your axis so they are not so high, or you will get a lot of clipping.
    Maybe 120 max or so, and then adjust the Max/Min settings to get the speed you want.
    Lower numbers are faster with less range, and bigger number are slower with more range.
    Take care!
  7. ProjectF1
    ProjectF1 Member
    Electrician
    304Coins
    thank you for your help, I'm going to try your advice to adjust my movements... I tested with LSF and I have the movements well, I feel the accelerations and inclinations on a slope perfectly. (also the vibrators on the circuit reproduce the vibrations well
  8. HASAN1453
    HASAN1453 Member
    Vr arcade owner
    VANCOUVER
    424Coins
    2DOF, 3DOF, Motion platform
    So I still don’t have a concrete answer how to setup ps5 (vr) with simtools. Can anyone help here? Quick explanation pls? I couldn’t find it in forums
    Thank you
  9. yobuddy
    51,524Coins
  10. HASAN1453
    HASAN1453 Member
    Vr arcade owner
    VANCOUVER
    424Coins
    Hello Youbuddy. Thabk you. I am talking more about that I have ps5 wanna use it psvr2, I have fasetech simulator and I have a pc :)
    Now in order to play a ps5 game let’s say GrandT, what do I do? Do I connect ps5 to the pc and Fasetech to the ps5, do I run the simtools from the pc or is there an app in ps5. Just in basic what connects to what and where do I start the game ? sorry maybe a bit confusing but basically how to do the setup if anyone can explain.
    thank you
  11. yobuddy
    51,524Coins
    The Simulator would connect to the same pc the runs simtools.
    The Ps5 simply runs the game, and is configured to send data to the pc running simtools.
    SimTools then catches the data and runs the simulator.
    So step one is getting your simulator connect and running from simtools on the PC.
    You can grab the Quick Start guide and the full manual from here.
    https://simtools.us/downloads-links/
    Hope this helps,
