DIY 2 DOF for Beginners
Discussion in 'DIY Motion Simulator Projects' started by Denis Mowberry, Mar 19, 2024.
  1. noorbeast
    153,794Coins
    +11,150 / 57 / -2
    Yes that is correct but will not stop you if negative, grab the plugins you need.
    Can you please post a picture of what you mean, is it asking for a patch path?
  2. Denis Mowberry
    Denis Mowberry Member
    New Zealand
    89Coins
    153,794Coins
    +11,150 / 57 / -2
    So is your DCS save game directory where indicated, or somewhere else?
  4. Denis Mowberry
    New Zealand
    89Coins
    After looking the save game directory is where indicated but the actual DCS World game is on a different drive do "I need to uninstall it and reinstall everything on one drive
    153,794Coins
    +11,150 / 57 / -2
    As per the popup advice you just need to ensure the save game directory is the one your install is actually using.
  6. Denis Mowberry
    New Zealand
    89Coins
    How do I check which directory it is using
  7. Denis Mowberry
    New Zealand
    89Coins
    I am still having trouble with DCS I have put in the path it asked for but it just says Failed to patch any ideas as to what I should be looking for. Thanks
    153,794Coins
    +11,150 / 57 / -2
    Can you please post s picture of the error message and the path you are trying.
  9. Attyla.pl
    Attyla.pl Active Member
    Polska
    1,336Coins
  10. Denis Mowberry
    New Zealand
    89Coins
    153,794Coins
    +11,150 / 57 / -2
    As per the notification the path may be different, are you sure you have the correct patch path?
  12. Attyla.pl
    Polska
    1,336Coins
    Enter the exact path to your game directory as in the image below, changing "YourName" to the username from your computer. Patch DCS.jpg
  13. Denis Mowberry
    New Zealand
    89Coins
    I have turned off the Beta version and am sure I am using the correct path but it just says game did not patch. Should I consider a reinstall any suggestions please
  14. Attyla.pl
    Polska
    1,336Coins
  15. Denis Mowberry
    New Zealand
    89Coins
    I have reinstalled DCS without Beta and still have the same problem Game did not patch . I dont know what to try next any suggestions please
  16. noorbeast
    153,794Coins
    +11,150 / 57 / -2
    Can you please post a picture of the patch path used and error message.
    Can you also please try and run SimTools as administrator and advise if that makes a difference.
  17. Denis Mowberry
    New Zealand
    89Coins
  18. Denis Mowberry
    New Zealand
    89Coins
    How Do I run sim tools as an administrator when I click on the icon it tries to reinstall the program and over write the existing on is that correct
    153,794Coins
    +11,150 / 57 / -2
    Right click on the icon, select More, then Run as Administrator.
  20. Denis Mowberry
    New Zealand
    89Coins
    Still no change . I guess I will give up on this one unless anyone has any other ideas .Thanks for all your help
