FlyPT Mover 3.5.3
  1. sallerding
    sallerding Member
    Perth, Western Australia
    344Coins
    Yes planned but still being worked on. Because it is being written voluntarily by a single member of the community (pmvcda) it will be released when he has an opportunity to complete his work. We all have to be patient, and grateful for the contribution he has made/making.
    • Agree Agree x 4
  2. Marco Annunziata
    919Coins
    Maybe it would be helpful if someone would offer to support him in the development of the code. Unfortunately, I'm not a developer otherwise I would have already offered myself.
    152,971Coins
    +11,115 / 56 / -2
    Given the complexities involved that is often not possible unless there are the resources to support a multi member development team.
    In the meantime we can all be appreciative of @pmvcda's efforts and FlyPt, and where we can choose to support him in whatever way is possible, given FlyPt is one of the free ways to bring our rigs to life, with a great deal of control over how that works!
  4. Marco Annunziata
    919Coins
    You right! I donated with PayPal and I suggest doing the same to other users, I suggest also @pmvcda start a Patreon crowd founding to have a controlled income and to know who the supporters are
  5. Map63Vette
    Map63Vette Active Member
    Mechanical Engineer
    Lawrence, KS
    709Coins
    What exactly do you mean? I managed to get SpaceMonkey output into FlyPT by manually running the Dirt 4 source in FlyPT. SpaceMonkey outputs data in the Codemasters format that Dirt 4 uses, so it seemed to pick it up just fine. So in that regard I think you can use any of the SpaceMonkey compatible games with FlyPT as long as you configure SpaceMonkey to output in the CM3 UDP format (CM3 = Codemasters extra 3).
  6. dureiken
    dureiken Active Member
    1,248Coins
    yes I did too, that way
    thanks
  7. Ronan Design
    Toronto, Canada
    1,721Coins
    What's the current status of FlyPT Mover with Elite Dangerous? I remember there was a whole memory address thing etc. but I last touched it 2 years ago so it's outdated most likely... What's the current way to connect?
  8. dureiken
    1,248Coins
    Hi, did someone tried PS5 compatibility ? maybe via SRS? thanks
  9. John Murphy
    John Murphy Member Gold Contributor
    Tech Exec
    Virginia, USA
    513Coins
    3DOF, DC motor
    I would like to connect simtools v3 to mover and have some questions...
    - for the source do I use the simtools plugin for mover (does this work with simtools v3?) or do i use udp?
    - I know I need the output:serial configured in mover, do I also need to setup something in 'direct'?
    -if anyone already has this configured (simtools v3 -> mover -> serial interface) i'd love to see your mover file.
    ( i have axis range and max/min configured in simtools v3)
  10. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,770Coins
    DC motor, 6DOF
    It’s quiet…. Any betas on the horizon?
    152,971Coins
    +11,115 / 56 / -2
    Read back a bit in the thread, so you are up to date with the life circumstances and pragmatic realities:
    My guess Betas and Releases will be done when they are done.
  12. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    Sure, sure
  13. pmvcda
    15,641Coins
    Working on the release.
    I have to be in Gothenburg for two weeks and after that i hope to have something in the end of september.
    My last struggles are with UDP to allow reuse of data.
    Not important at first sight, but i need it for some future features. For now it will allow using the same port to send/receive data in multiple sources/outputs.
    • Like Like x 9
    • Friendly Friendly x 3
  14. michel123
    michel123 Member
    cadre sncf
    lezignan-corbieres
    220Coins
    • Friendly Friendly x 2
  15. michel123
    michel123 Member
    cadre sncf
    lezignan-corbieres
    220Coins
    For the creator of flyPT mover (aka FlyPT) , I have never thanked you!
    So.... THANK YOU VERY MUCH FOR THIS JEWEL AND ALL THE WORK DONE SINCE SOON.... 10 YEARS??? !!!! :thumbs
    Admirer and absolute fan, like many people we are waiting for the new version, and don't hesitate... 40 € without worries or more!!
    As soon as this comes out I'm buying!!!! ;)
  16. Ronan Design
    Toronto, Canada
    1,721Coins
  17. Ronan Design
    Toronto, Canada
    1,721Coins
    I have another issue/question - with the vibration feedback. I use 3 different sound-generating functions in Elite Dangerous - fire1, fire2 and throttle. I also use engine RPM and Gear shift in Euro Truck Simulator. They all work fine, but they share the same behaviour: when the profile is loaded they all generate loud continuos noise/vibration by default. It disappears after all sources for the sounds are triggered once. I.e. I need to press both joystick fire buttons and move the throttle a bit - and then it's all quiet and works perfectly from that point. Throttle on 0 is quiet, same for joystick - only vibrating on pressing buttons.
    What could be the reason for that? Is there any way to prevent it from vibrating on initial load, and why is it doing that? Here's how a typical transducer function looks on my profiles:
    Joystick buttons and axes are mapped to otherwise unused variables - clutch in this case:
  18. sallerding
    sallerding Member
    344Coins
    Curious to know whether anyone has been able to use the phyphox source recently or whether it needs updating?. Wasn’t able to have it recognise some data I collected from a flight. Checking to see if it’s me or the source?
  19. Ronan Design
    Toronto, Canada
    1,721Coins
    And another question: apparently with the custom hooks for Elite Dangerous there are different sources for the ship and the SRV (planetary vehicle), and SRV sometimes gets weird accelerations in space where it should not send anything. The SimTools plugin author simply slaps a condition there to only process SRV source when the sum of ship accelerations is 0 (i.e. when SRV is in use and not the ship). But I don't see any way I can do it in FlyPT Mover. Is it possible to assign/check specific variable in the VALUE formula so only process it when something else is 0? Or maybe reject ridiculous values beyond certain range - kinda like MAXCROP but without retaining the max value, but keeping 0 instead when the value is above threshold?
  20. smitty
    smitty Active Member
    935Coins
    yep i've had that behavior.. luckily for flight sims there are other haptic programs so im using them instead
