DIY FFB Steering wheel (MMosFFB ) (In Progress)
Discussion in 'DIY peripherals' started by Alexey, Dec 10, 2015.
  1. elnino
    elnino Active Member
    Computer Geek
    Adelaide, Australia
    1,557Coins
    All of them should work fine but MMOS is pretty outdated these days. EMC Pro on an STM32F407 or OpenFFBoard would be the way to go.
    Both are still in development, but both have somewhat left behind traditional H Bridge control (OpenFFBoard more so, only older versions still support it). EMC is a bit more DIY whereas OpenFFBoard promotes using their specific manufactured boards (but you can use a generic dev board).
  2. Abhay
    Abhay New Member
    56Coins
    hey man, I am building a DIY FFB wheel and everything works great except pedals.
    when I keep motor off they work great but when I turn on motor, the pedals start flickering crazy, like almost half range flickering.
    do you know why this is happening and how can i solve it?
  3. Wayne Thebus
    Wayne Thebus Member
    CNC Machinist/Programmer
    Cape Town
    105Coins
    How have you connect the pedals to the Arduino? Are you using Dupont style connections wires? I had a similar problem and it was resolved when I soldered the wires direct to the Arduino. I hope this helps, it did work for me.
  4. Abhay
    Abhay New Member
    56Coins
    yeah its dupont flat rainbow cables.
    so can i just twist all 5v cables together and solder them to arduino?
  5. Wayne Thebus
    Wayne Thebus Member
    Cape Town
    105Coins
    Hi how many 5V cables do you have(that can work) all the other wires need to be soldered also, because the Dupont style connections don't all work well especially the cheaper ones. The best practice is to solder to the pads on the back of the Arduino board an make sure to use some type of insulation to prevent shorting out the wires. Have a look @ what I did in the share picture.
  6. Abhay
    Abhay New Member
    56Coins
    pedals, handbrake and motor driver. total 3 5v cables.
    yes, soldering on back on arduino seems like a solid choice. I will try that.
    BTW what type of shielded cable are you using, did you buy it or remove it from somewhere?
  7. Wayne Thebus
    Wayne Thebus Member
    Cape Town
    105Coins
    I just cut a length of RJ45 network cable, and I use the RJ45 socket to connect the Arduino to my diy pedals.The 8 wires inside are more than enough for my pedals.
  8. Abhay
    Abhay New Member
    56Coins
    so if I just solder dupont cable will it work or would I need other cable like you are using
  9. Wayne Thebus
    Wayne Thebus Member
    Cape Town
    105Coins
    Soldering will be the best practice, but be sure to solder @ both ends of the Dupont style connections, to ensure positive connections. I hope this works out for you, I know how frustrating that glitching pedals can be. Best of luck and please let me know if it works, thanks.
  10. Abhay
    Abhay New Member
    56Coins
    yeah will let you know, thanks
  11. Abhay
    Abhay New Member
    56Coins
    hey, so I soldered everything and sadly it didn't improve the flickering. will need to try something else
  12. viru
    viru New Member
    6Coins
    Joyrider
    I dint see this diagram in ebolzmagy yt channel can u provide link
  13. noorbeast
    154,705Coins
    +11,210 / 57 / -2
    It was in the post:
