Need U-joint recommendations
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Zyadox, Mar 3, 2016.
  1. Zyadox
    Zyadox New Member
    196Coins
    Hello all,
    I'm currently following Floriske's 2DOF sim build. Here is the link on x-sim:
    http://x-sim.de/forum/viewtopic.php?f=36&t=617
    Its profile is just what I'm looking for, he's made his plans available, and detailed his process very well. That being said, I'm struggling with acquiring / creating a working U-joint. The solutions I've found online all seem to require some welding skill (of which I have none, let alone a kit), and haven't been able to find a solution.
    Can you think of anything off the top of your head that may substitute well or am I SOL? Thank you for taking the time to respond - I appreciate your feedback!
  2. rattler
    rattler
    @Zyadox
    I am only new here, but I think @Wanegain did a design using spherical rod ends for a uni joint. No welding needed. I have also seen a car engine mount used as it has bolts going through it and I think a draglink setup was used to stop torsional twist.
    Im going the cut down uni joint as I have a welder.
    .....I really must note down where I find this info and link it.....:D
    153,764Coins
    +11,149 / 57 / -2
    I use a universal joint from an old car tailshaft, it requires cutting and welding on a mount plate but is strong and very smooth in movement.
    Other use a steering column universal joint, some fabricate a joint from multiple rose joints.
  4. Wanegain
    Wanegain Active Member
    Bruxelles
    2,018Coins
    You can try to build one :
    • Like Like x 5
    • Creative Creative x 2
  5. Zyadox
    Zyadox New Member
    196Coins
    Thanks for the feedback, everyone!
    @Wanegain , fantastic idea! How would you describe the durability, angles of movement, and stability of your idea? It seems to be just the solution I'm looking for. If I may, what are the rod ends attached to in the middle and what size are your rod ends?
  6. Wanegain
    Bruxelles
    2,018Coins
    The durability depends on what material you use to fix it, but the universal joint itself should not be degraded.. For angles there is no restriction. With this solution, it's possible that there is a small backlash because of the elasticity of wood. I am using 10mm threaded rods.
  7. Nick Moxley
    I highly suggest using the Fully captured Rod ends if your going to use that route...The cheaper rod ends IMO slop out alot faster.
  8. phisado
    phisado New Member
    bangkok
    302Coins
    :thumbs
  9. Kevin S
    Kevin S New Member
    34Coins
    2DOF, 3DOF, Arduino, Motion platform
    I had a hard time finding a U-Joint, so I purchased:
    • Youll need one of these, about $36
    Spicer 5-1310X U-Joint Kit 1310/SPL22 Series (OSR)
    • You'll need two of these. About $27 each
    DRIVESHAFT FLANGE YOKE - 1310 SERIES - PDM 2.75 FFC 1.375
    153,764Coins
    +11,149 / 57 / -2
    There are some initial limitations on new members to prevent spam: https://www.xsimulator.net/communit...ed-posts-needed-before-links-can-be-used.150/
    After that see the FAQs here as to how to embed video into a post: https://www.xsimulator.net/community/faq/insert-a-video-into-a-post.257/
  11. stratman71
    stratman71 New Member
    - 134Coins
    4DOF
    I got mine on ebay, has bolt holes on both ends so you may be able to find a weldless way to attach. Search for "CARDAN SHAFT FLANGED UNIVERSAL JOINT U JOINT HIGH ANGLE"., cost is about 65$ usd.
  12. PhillyNJ
    PhillyNJ Member
    153Coins
  13. Kevin S
    Kevin S New Member
    34Coins
  14. Attyla.pl
    Attyla.pl Active Member
    Polska
    1,336Coins
  15. Rodeo5150
    Antioch, CA, United States
    1,251Coins
    Arduino, 6DOF
    I got these from eBay I think for maybe around $20 a piece I think maybe a little bit more
  16. Rodeo5150
    1,251Coins
    Arduino, 6DOF
    I've also three printed my own still holding up my full size hexapod
  17. Aerosmith
    Aerosmith Active Member
    self employed
    2,881Coins
    3DOF, AC motor
    I've found the center pieces of those U-joints at several online shops. I don't know how they are called but from the shape I'd guess something like X-joints or X-bearings. On AliExpress they are only around $5..10.
    From the picture from Rodeo5150's post above we can guess how the U-joints are assembled. You can't insert the X into the forks directly but with the needle bearing caps removed it might work. Then you can put the caps back on from the outside of the holes in the forks and the allen key screw secures them.
    The 3D-printed parts should be strong enough when pressure loaded, only. But I have some doubts what happens if an actuator accidentally pulls instead of pushing. FDM printed parts can easily de-laminate and are not very strong under tensile load.
    Complete U-joint assemblies are available as spare parts for cars. But all I've found have quite awkward shaft connections that are longer and heavier than needed for motion rigs. You'd have to cut them with the angle grinder and weld them to a base plate or (spline/toothless) shaft coupling.
    How about machining them out of aluminium?
  18. Jango
    Jango Member
    Mauritius
    372Coins
    2DOF, DC motor
  19. early_m
    early_m Active Member
    Chelmsford
    839Coins
    Ive got a few assembled u-joints available. DM if interested
  20. Cold Pancake
    Cold Pancake New Member
    90Coins
    I just bought a kei car u-joint (6 bucks only) and sent it to a machine shop to add a flange for mounting. It holds pretty well for now :thumbs
