DIY FFB Pulley and Belt selection
Discussion in 'New users start here - FAQ' started by Furkan54, Jun 20, 2024.
  1. Furkan54
    Furkan54 New Member
    16Coins
    DC motor
    Hi, im currently Making a ffb Wheel i‘ve got almost everything the only thing that i Need Are Belt and Pulleys firstly im using a my1016 motor wich has 0,87 nm Torque im going to use 60 teeth on the steering shaft and 15 teeth on the motor thats enough for now im just struggling on choosing the Right pulleys i now Need advice on wich size i should take ive read there Are 5m and 3m now wich one is better? Does someone have Experience. Thank you!
  2. X.STTONER
    X.STTONER Sttoner
    business manager
    lima
    232Coins
    2DOF, 3DOF, DC motor, AC motor, Arduino, Motion platform, 4DOF
    The belt to use is in relation to the pulleys you have. There are several types of models as well as width and length. To give you an idea, there are gt2 gt3 gt5 pulleys as well as htd m3 htd m5 and many more.
    The difference is the size of the tooth and the steps as well as the force it supports. I think you should choose that according to the power of your motor.
