SMC - Are Motors Feedback 1 & 3 linked?
Discussion in 'SimTools compatible interfaces' started by Eli Wizard, Aug 7, 2024.
  1. Eli Wizard
    Eli Wizard New Member
    Ottawa
    32Coins
    Hi All,
    I'm adding a third motor to my rig and in SMC while setting up M3 pot I'm getting additional feedback registering on the M1 axis. This does not happen when moving the M2 pot or when the M1 pot is moved does not affect the M3 axis. I've made sure that polarity is the same on all pots but I still get the same result. Is this normal or do I still have some connections to sort?
  2. Gadget999
    12,132Coins
    Check your wiring
  3. Eli Wizard
    Ottawa
    32Coins
    Capturefive.JPG I've torn all the connections apart and rebuilt twice, changed motor pins but always get the same result: movement on one specific pot(A) also registers (somewhat reduced) on another specific pot(B). There is no change on pot C. There is no change to pot A if pot B is moved.
    Check out the screenshot. What would be the cause of this?
  4. Gadget999
    12,132Coins
    Check which pin is programmed in the code
  5. Eli Wizard
    Ottawa
    32Coins
    Pin assignments are correct. I've even shuffled them and still get the same result in relation to the pots. Could wire gauge/length be a factor?
  6. Gadget999
    12,132Coins
    allocate to a new pin an check it works ok
  7. Gadget999
    12,132Coins
    what type of board - is it compatible ?
