Showroom From prototype to my finished 2 DOF
Discussion in 'DIY Motion Simulator Projects' started by Johann007, Aug 13, 2024.
  1. Johann007
    Johann007 New Member
    51Coins
  2. Jango
    Jango Member
    Mauritius
    372Coins
    2DOF, DC motor
    Hi Johann,nice build.
    What is the voltage that you are using for your motor?
    Also kindly let me know the dimension of the connecting rod which you used, whether M12 or M10 ? Thanks
  3. Johann007
    51Coins
    Hi, i use 220V because i live in Germany.
    I have 10M but You can also use 12M, because the 2 connecting rod are togehter, See the picture.
  4. Jango
    Jango Member
    Mauritius
    372Coins
    2DOF, DC motor
    Thank you Johann,
    The setup looks very clean.
    I recently ordered the M10 rod ends (as they were the only ones available on amazon), then I wondered if they would be too weak. I'll give them a try once received.
