My 6DOF Motion sim
Discussion in 'DIY Motion Simulator Projects' started by Genociple, Sep 2, 2024.
  1. Genociple
    Genociple New Member
    62Coins
    I am not an engineer whatsoever, yet im currently working on my associates then towards a mechanical engineering degree. Please forgive my crappy terminology and mixup of names of things.
    So far i have a 6DOF stewart platform made from hobby servos using an ESP32 dev board and FlyPT software
    I also have a rig in process of being built(based off of Next level racing F-Gt Elite)
    Crappy cad model of full scale stewart platform
    next up is motors. Still at a loss of what to do for cheapest motor setup for moving 150kg(me and rig)(total is less than that but using that as a benchmark)
    153,830Coins
    +11,151 / 57 / -2
    Any 6DOF is an ambitious first project. So doing some research before getting in too deep is time well spent, as is building a working model, as you have done :thumbs
    Bounce your full size plans and shopping list off members before jumping too far down what can be an expensive rabbit hole, if you get it wrong. Following in the footsteps of others will likely save some time, frustration and money.
    AASD15A servos are currently the most popular high powered option for these types of rigs, be they rotary or actuator designs, and there are a number of existing hardware controllers that almost make them plug and play, just make sure you check with members in your bulid thread and controller developers like @Thanos before ordering, to make sure you have the correct and properly shielded servos, if you go down this well defined pathway: https://www.xsimulator.net/community/faq/amc-aasd15a-servo-controller.351/
  3. Genociple
    62Coins
  4. Genociple
    62Coins
    Here is my cad model for my rig, made with 5050 aluminum extrusion and 1/4 aluminum for the brackets
    very adjustable, from my real car seating position all the way to f1 position.
  5. Genociple
    62Coins
    Also another thing to consider, i live in an apartment, i have 15-20 amps to work with so what motors would be recommended, possibly something i can find in a junkyard maybe? treadmills, washer/dryer? idk.
  6. Genociple
    62Coins
    I also saw a tutorial using those hover board motors to make a sim wheel, could i use 6 or 12 of those for 150kg moving
  7. Genociple
    62Coins
    My rig rough draft dimensions are as follows:
    1200mm base
    600mm platform
    500mm height
    153,830Coins
    +11,151 / 57 / -2
    Keep in mind that not only is a load not evenly distributed on a motion rig, the fast moving mass also has significant inertia.
    Cheap junkyard motors are not likely to cut it and the complexity and associated cost of multiple controllers for say powerful 12/24v motors is a serious consideration. Odrive motors are a possibility and have been used before, but the control side can be finicky to sort and get running reliably.
  9. Genociple
    62Coins
    odrive motor or odrive controller? im not sure that im able to find odrive motors
    153,830Coins
    +11,151 / 57 / -2
  11. Genociple
    62Coins
    After looking at it a bit, ive found a robodog example using odrive, hoverboard motors, and absolute hall sensors.
    im using that leg force excel with the rough draft dimensions and each leg will have 300N resting force and 600N at 1G heave acceleration.
    if at a crank arm of 100mm that 30-60Nm of torque. I would need 1:5 reduction to be able to use the 13Nm hoverboard motor. since its only 1:5 i was thinking of a capstan reduction drive(would be minimal backlash too)
