FlyPT - 3DOF Brushless DOF3
Discussion in 'DIY Motion Simulator Projects' started by Deleted member 38270, Sep 14, 2024.
  1. Deleted member 38270
      113.4 KB
      161
      135 KB
      147
  2. Deleted member 38270
    i
    think that it will be easier to control BLDC motors than inverters.
    I would like to base the project on the photo
    Regards
    Tadek
      113.4 KB
      192
  3. Attyla.pl
    Attyla.pl Active Member
    Polska
    1,344Coins
  4. Deleted member 38270
    Hi
    Thank you for a nice thread Attyla
    I have questin
    The motor controller BLDC is powered by 230v ?
    best regards
    Tad
  5. pmvcda
    15,535Coins
    No
  6. Deleted member 38270
    Hi
    I guess there are 3 ways?
    1. 24V DC motor + reg+SMC3 (Arduino)
    2. 230V motor controlled by a Modbus inverter
    3. Servo motor (80ST-M02430) +Thanos
    I would like to use 750-1000W motors
    what is best to choose?
    152,603Coins
    +11,087 / 56 / -2
    There are a range of possible criteria but in terms of ease of use the @Thanos AMC-AASD15A controller is close to plug and play: https://www.xsimulator.net/community/faq/amc-aasd15a-servo-controller.351/
  8. Deleted member 38270
    oh great
    and why is it so expensive?
    Can we replace this driver with something?
    Is the control via modbus?
    best regards
    Tad
    152,603Coins
    +11,087 / 56 / -2
    Expensive depends on what you cost in, including your time.
    There are a range of possible criteria, here are just some alternatives that may be considered, for example:
    https://www.xsimulator.net/communit...o-mega-for-aasd-15a-and-similar-driver.14421/
    https://www.xsimulator.net/community/faq/motion4sim-6dof-aasd15-servo-motion-controller.392/
    https://www.xsimulator.net/community/threads/compact-ac-servo-6dof-rotary-stewart-platform.14769/
    https://www.xsimulator.net/community/threads/flypt-6dof-brushless-diy-actuators.10799/
    And more if you search further.
  10. Deleted member 38270
    Noorbeast
    You are irreplaceable
    Thank you very much
