FlyPT Mover 3.7.0.14
  1. mm982566
    mm982566 New Member
    US
    56Coins
    3DOF, 4DOF, 6DOF
    I found that ETS2 and ATS are missing
  2. GTakacs
    GTakacs Member
    430Coins
    Can you post an update when the new binary is posted and what had been fixed/improved. I mainly need iRacing source for starters. I'm in the US so time difference will make feedback kind of async.
  3. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,770Coins
    DC motor, 6DOF
    I would advocate for a bigger gui size and font size by 1,5x-2x
    Please like the post if you find the idea handy
    • Like Like x 5
  4. pmvcda
    15,434Coins
    I will. I just added iRacing, just checking some data I'm missing there (location and vehicle) needed for default setups.
  5. smitty
    smitty Active Member
    933Coins
    should the download include more than the exe? when i try to add MSFS source it crashes becuase it cannot find simconnect.dll. I tried copying one into the folder but still no luck.
  6. GTakacs
    GTakacs Member
    430Coins
    Set Scale to 100%, start Mover, everything looks good/location of fields and sizes are correct.
    Shut down Mover, change scale to 150%, start Mover, add a Pose or a Source, position and size of fields is incorrect.
    Also, if you load up a previously saved setup the monitor positions will be incorrect/changed once the scale is changed.
  7. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    same here
  8. Markypops
    Markypops New Member
    64Coins
    I'm probably in a minority, but small is good for my use at the moment. I need to show lots of stuff on a 1080p monitor. (We're transmitting video over wifi from a moving pc).
  9. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    I am also on 1080. Just remarked we can resize the window which is great so maybe it’s good not to mess up with the fonts more than needed. (Could be bigger IMO but It can create other inconsistencies)
  10. pmvcda
    15,434Coins
    Simconnect problem, you can try to put in the same folder the dll
    Not sure it will solve, I'm having problems to include it in the exe
  11. pmvcda
    15,434Coins
    I'm not doubting you, but on my side it's ok, tested in two PC's
    Can someone else try please
  12. GTakacs
    GTakacs Member
    430Coins
    Only thing is that I have a dual monitor setup, one is a 4k built-in (laptop, running at 150% scaling) and an external ultrawide running 1440p at 100% scaling. So this could be why I'm seeing the problem maybe?
  13. pmvcda
    15,434Coins
    I will try on my rig tomorrow. I use two screens, one ultrawide.
  14. smitty
    933Coins
    didnt work, also tried renaming it to 'Microsoft.FlightSimulator.SimConnect.dll' as shown in the error message
  15. smitty
    933Coins
    poking thru some of the filters, seems the old WASH took 3 inputs while 3.7 only has one:
  16. Marco Annunziata
    895Coins
    I tried all the motion algorithms but I think it didn't work, both in VR motion compensation and the 3D view I can't see the behavior of the actuator in the "Linear hexapod (6DOF)" module. Am I wronging something?
    (The video starts after 7 seconds, please wait)
  17. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    I have a reaction to the Thanos board with 230400 but the actuators doesn’t lift symmetrically up so I am stopping the movement with a kill-switch
    Edit: maybe bad setting in rotary module
  18. Trigen
    Trigen Active Member
    2,872Coins
    I also have issues with serial and Thanos in 3.5.3 and 3.7 while the Thanos AMC works just fine.
  19. pmvcda
    15,434Coins
    Coming soon. Most of the code is done just needs some updates.
  20. pmvcda
    15,434Coins
    Sorry, forgot that I disable the effect by default. At the right of the motion alghorithm, there's a setting for that.
    0 is disabled and 1 maximum makes no movement. Try 0.1
