FlyPT Mover 3.7.0.15
  1. dureiken
    dureiken Active Member
    1,248Coins
    Hi @pmvcda , thanks for all your work
    Will it be possible in this version to create our own module/rigs ? In order to make something locked and beginner/advanced mode as already discussed ?
    thanks a lot
  2. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,770Coins
    DC motor, 6DOF
    @pmvcda
    It's hard to say anything intelligent, but the solution could be to stop the movement when the command goes from one “out of reach” and enters into another one.
    For now, from what I see, although the command is already in the next “out of reach”, the movement continue to the last possible one.
  3. pmvcda
    15,472Coins
    I will look at it later, but I think I know where is the problem. It's related to reseting the transition timer.
  4. pmvcda
    15,472Coins
    Yes it will be possible with plugins
  5. khairul nizam
    khairul nizam dadima
    Retails
    Malaysia
    71Coins
    2DOF, DC motor
    If I need to make the movement smoother, it reaching the target a bit fast, how can I adjust that? I am using Pose From Motion. Where should I put the filtering? Is it in the out gain section? What would be the value should be in there, let say I need the pitch to be like 15° up and down, and I need the curve to be slower at start, and reaching the target slowly following a nice curve.
    Any helps would be appreciated. Thanks
  6. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    You can keep this basic rule in mind:
    Exponential Moving Average Low Pass (EMALP) 1st. Order:
    EMALP 2nd. Order:
    EMALP 3rd. Order:
    EMALP 1st order keeps the response pretty vivid which means the start impulse will remain swift and slow down just after. (Higher value more smoothing effect)
    If you want to smooth the first impulse as well use EMALP second or third order. (One EMALP over another).
    you can add EMAHP (High pass) to keep the movement close to the center (Lower value faster return effect)
    That’s simple nevertheless very powerful basics to start with.
    Edit:
    In most of the cases you don’t need more than that - with a good balance of those combinations you can go very far in signal processing.
    Experiment with this before you choose more advanced filtering.
  7. pmvcda
    15,472Coins
    There's now a WASHLT filter. Here you can set the maximum speed a value goes back to zero.
    WASHLT(VALUE;10)
    Means the maximum speed is 10mm/s or 10º/s if a rotation
    Example in action (red after filter):
    We can see that the variations are kept but the value is going back to zero.
    With some noise:
    Would like to smooth start and stop, but it's near impossible to do it. I have no ideas right now for that.
    EDIT: But this is washout not any target value, for that there's a MAXDELTA if I remember...
  8. pmvcda
    15,472Coins
    Is this the follow alghorithm or the transition from last good pose?
    Sorry, can't see in the image
    EDIT: Ignore, I already know, in my test I was using the wrong one lol
  9. khairul nizam
    Retails
    Malaysia
    71Coins
    2DOF, DC motor
    Thanks for explaining about EMALP. For the 1st order, if I want it to really slow down upon reaching target, so I should set higher EMALP to smoothen it out better?
  10. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    Higher values for the 1st order EMALP alone will make the “corner” less steep (abrupt), nevertheless you’ll always keep the small kick. Imagine a zero delay reaction.
    second order:
    Third order:
  11. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    You understood I think, it depends what and how you want to “smooth it better” :).
    Use 1st order if you want to keep signal details (no delay) and use ordering 2nd or 3rd if you want to make everything smooth and swim.
    Most of the time I use on a 6-dof 1st and 2nd order for the main dofs and 3rd order for coordination channel. (Mix surge in pitch - mix sway in roll)
  12. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    Stay on last good
  13. pmvcda
    15,472Coins
    @hexpod ,
    Seems it's solved for next release. Hope tomorrow. In the middle of other problems...
    Looking close, we can see the transition is made and that while transition is performed we follow the latest requests to the rig
  14. pmvcda
    15,472Coins
    Some new features in Mover:
    Actuators with two poses, one for each joint:
    New types of actuators:
    A bar with a joint on a linear rail (sliding linear):
    That actuator on a rig:
    A bar with a joint on a circular rail (sliding linear):
    The actuator on a rig:
    Some others....
  15. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    System.InvalidOperationException: Collection was modified; enumeration operation may not execute.
    at System.Linq.Enumerable.OfTypeIterator[TResult](IEnumerable source)+MoveNext()
    at System.Linq.Enumerable.WhereEnumerableIterator`1.MoveNext()
    at Mover.Devices.Utils.UpdateDevicesListsInUI() in C:\Users\pedro\source\repos\Mover3\App\Devices\Utils.cs:line 9
    at Mover.Devices.Joysticks.Update() in C:\Users\pedro\source\repos\Mover3\App\Devices\Joysticks.cs:line 158
    at System.Windows.Forms.NativeWindow.Callback(HWND hWnd, MessageId msg, WPARAM wparam, LPARAM lparam)
    System.Private.CoreLib
    Assembly Version: 8.0.0.0
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Private.CoreLib.dll
    Mover
    Assembly Version: 3.7.0.2
    System.Runtime
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Runtime.dll
    System.Drawing.Primitives
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Drawing.Primitives.dll
    System.ComponentModel.EventBasedAsync
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.ComponentModel.EventBasedAsync.dll
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\8.0.8\System.Windows.Forms.dll
    System.Windows.Forms.Primitives
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\8.0.8\System.Windows.Forms.Primitives.dll
    System.Runtime.InteropServices
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Runtime.InteropServices.dll
    System.Threading
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Threading.dll
    System.Diagnostics.TraceSource
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Diagnostics.TraceSource.dll
    System.Collections
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Collections.dll
    System.ComponentModel.Primitives
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.ComponentModel.Primitives.dll
    System.Drawing.Common
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\8.0.8\System.Drawing.Common.dll
    System.Collections.Specialized
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Collections.Specialized.dll
    System.ComponentModel.TypeConverter
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.ComponentModel.TypeConverter.dll
    Microsoft.Win32.Primitives
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\Microsoft.Win32.Primitives.dll
    System.Threading.Thread
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Threading.Thread.dll
    Accessibility
    Assembly Version: 4.0.0.0
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\8.0.8\Accessibility.dll
    System.Numerics.Vectors
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Numerics.Vectors.dll
    System.Resources.Extensions
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\8.0.8\System.Resources.Extensions.dll
    System.Memory
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Memory.dll
    System.Drawing
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\8.0.8\System.Drawing.dll
    Microsoft.Win32.SystemEvents
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\8.0.8\Microsoft.Win32.SystemEvents.dll
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.ComponentModel.dll
    System.Collections.Concurrent
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Collections.Concurrent.dll
    System.Runtime.Loader
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Runtime.Loader.dll
    System.Linq
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Linq.dll
    Microsoft.Win32.Registry
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\Microsoft.Win32.Registry.dll
    System.ObjectModel
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.ObjectModel.dll
    System.Diagnostics.Process
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Diagnostics.Process.dll
    System.Collections.NonGeneric
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Collections.NonGeneric.dll
    Microsoft.Windows.SDK.NET
    Assembly Version: 10.0.17763.24
    WinRT.Runtime
    Assembly Version: 2.0.0.0
    System.Runtime.CompilerServices.Unsafe
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Runtime.CompilerServices.Unsafe.dll
    System.Security.Cryptography.Algorithms
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Security.Cryptography.Algorithms.dll
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Security.Cryptography.dll
    System.Private.Uri
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Private.Uri.dll
    System.Linq.Expressions
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Linq.Expressions.dll
    System.Reflection.Emit
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Reflection.Emit.dll
    Snippets
    Assembly Version: 0.0.0.0
    System.DoubleNumerics
    Assembly Version: 1.0.0.0
    System.Configuration.ConfigurationManager
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\8.0.8\System.Configuration.ConfigurationManager.dll
    System.Text.RegularExpressions
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Text.RegularExpressions.dll
    System.Resources.Writer
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Resources.Writer.dll
    System.Runtime.Serialization.Formatters
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Runtime.Serialization.Formatters.dll
    System.Xml.XDocument
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Xml.XDocument.dll
    System.Private.Xml.Linq
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Private.Xml.Linq.dll
    System.Private.Xml
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Private.Xml.dll
    System.Security.AccessControl
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Security.AccessControl.dll
    System.Security.Principal.Windows
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Security.Principal.Windows.dll
    System.Runtime.Numerics
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Runtime.Numerics.dll
    System.Net.Primitives
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Net.Primitives.dll
    System.Formats.Asn1
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Formats.Asn1.dll
    System.Reflection.Emit.ILGeneration
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Reflection.Emit.ILGeneration.dll
    System.Reflection.Primitives
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Reflection.Primitives.dll
    System.Reflection.Metadata
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Reflection.Metadata.dll
    System.Xml.ReaderWriter
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Xml.ReaderWriter.dll
    System.Security.Claims
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Security.Claims.dll
    System.Collections.Immutable
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Collections.Immutable.dll
    System.IO.Ports
    System.Text.Encoding.Extensions
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Text.Encoding.Extensions.dll
    mscorlib
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\mscorlib.dll
    System.Runtime.Extensions
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Runtime.Extensions.dll
    NWaves
    Assembly Version: 0.9.6.0
    Mythosia.Integrity
    Assembly Version: 1.2.0.0
    netstandard
    Assembly Version: 2.1.0.0
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\netstandard.dll
    Microsoft.CSharp
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\Microsoft.CSharp.dll
    System.Reflection.Emit.Lightweight
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Reflection.Emit.Lightweight.dll
    Anonymously Hosted DynamicMethods Assembly
    System.Threading.ThreadPool
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Threading.ThreadPool.dll
    System.Diagnostics.StackTrace
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Diagnostics.StackTrace.dll
    System.IO.Compression
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.IO.Compression.dll
  16. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
  17. pmvcda
    15,472Coins
  18. Ronan Design
    Toronto, Canada
    1,720Coins
    I just had a crazy idea... Can new FlyPT Mover to control Force Feedback for yokes?
    I have a DIY pendular yoke that uses bungee cords for springs - very smooth. So I just thought that if I can make 2 stepper motors tension the bungee cords in Pitch and Roll and feed it some data from the sim through FlyPT I will make a Force Feedback yoke! With yokes the important thing is that the resistance grows depending on the deflection of a control surface and speed. So when you trim the yoke for a desired attitude, you feel it stop fighting you. Nothing violent is needed, just pulling the center of tension this way or that.
    I could get small DC motors and drive them with IBT-2s - what data I can use from FlyPT? I see strangely named values in FS2020 source:
    - Front Left Surface
    - Front Right Surface
    - RearLeft Surface
    - Rear Right Surface
    They are not in SimConnect SDK, so nor sure what they are... Are they deflections of control surfaces like ailerons and elevators? If so, I could take them and multiply by speed and that should give me an approximation on forces acting on the yoke. But are they something else maybe?
    If deflection angle or a position of ailerons or elevators is not available @pmvcda can you please add them as values for the source? That would open up force feedback scenarios. The variable are listed here.
    Maybe control Nema 17 stepper motors in some way? Is it feasible with SMC3 maybe? I have 3 such motors in an old broken 3D printer. But I can't figure out if I can make the chain from FlyPT - Arduino (SMC3?) - Stepper Motors. Any ideas?
  19. pmvcda
    15,472Coins
    I can add the vars in the next release.
    The surface is the type of surface in contact with the landing gear.
    For the FFB, we can do it. There's no hid, but with the info you can create effects by mixing the source values and what is read from the "standard" joystick.
    I'm working on something like that, but just in project for now.
  20. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    @pmvcda could you please briefly describe the simplest method to save and load different preset for different planes ?
