Resolved 2DOF motion sim - for flight sim - Wooden frame
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Jango, Oct 9, 2024.
  1. Jango
    Jango Member
    Mauritius
    360Coins
    2DOF, DC motor
    Good day everyone,
    I am slowly building my motion sim, which is mostly based on SCK Gaming's design - motor, potentiometer, arm etc.
    However, I am building it with wood, as it is easier for me.
    I am using the wheelchair motor at 75 rpm 24V 250W and since i'll be using it mainly for flight sim, i was wondering what would be the ideal -ve and +ve deflection of the motor arm to achieve a noticeable effect.
    The platform is compact and will have clearance issues.
    Assuming that the arm will be horizontal at rest position, i am planning a 25 degrees down and a 35 degree up (from the initial horizontal position).
    - Please let me know if i need to account for dips (to the original 25 deg down) as the motor changes direction. (and considering wood might have some flex also)
    - and whether 25 deg down and 35 deg up is too much.
    Thanks a lot.
    152,541Coins
    +11,085 / 56 / -2
    Around 38 degrees up and down is about the limit before physics dictates a significant degradation of effective torque utilisation.
  3. Jango
    Jango Member
    Mauritius
    360Coins
    2DOF, DC motor
    Thank you very much noorbeast, that is helpful and will help me to work on the locus and clearances.
  4. Attyla.pl
    Attyla.pl Active Member
    Polska
    1,338Coins
    My wood motion sim
  5. Jango
    Jango Member
    Mauritius
    360Coins
    2DOF, DC motor
    amazing build !
  6. M.a.t
    M.a.t New Member
    mecanic
    - 11Coins
    Good morning
    very nice achievement
    do you have any other photos of the mechanical system used?
    THANKS
