Question About Communicaiton Protocol of Sim V3
Discussion in 'SimTools DIY Version' started by William816, Oct 11, 2024.
  1. William816
    William816 New Member
    48Coins
    I am trying to build up my own 3dof simulator by using PLC. However, there are 2 quesitons confuse me and ask your support:
    1. Normally, to communicate with PLC, it is naccessary to using Communication Protocol. e.g. modbus etc.
    So what Communication Protocol does Simtools V3 exactly used for communication?
    2. I read the broucher of Simtools V3 about interface output. If I just use the type<axis1a><axis2a><axis3a><axis4a>, does is means I will receive four numbers among 0-255. Or I will receive 4 char type string?
    153,914Coins
    +11,156 / 57 / -2
  3. yobuddy
    51,539Coins
    When selecting 8 bit output, you will get 4 chars as a string if you choose binary output, and 4 number between 0-255 all stuck together as a single sting when send as decimal.
  4. William816
    48Coins
    Thank you for the reply firstly. However, as the freshman of C++, know little about C++(mainly work on PLC programing normally). It is hard to compile API by using C++, so~~~~can I just use exist serial interface for my own simulator or it is must to custom an interface for DIY simulator?
    Lookog forward to your reply. Thanks.
  5. William816
    48Coins
    em.... I have read all related FAQ about API. It seems there is no answer about my question 1. For PLC communication, it is needed to have a "Communication Protocol". So how or where can I define the communication method in simtools? or how can I define the communication method when compile an interface?
  6. yobuddy
    51,539Coins
    Do you connect the PLC to the PC thru a networking cable or serial cable? And then what does a move axis command look like?
  7. William816
    48Coins
    Thanks buddy, the problem sovled. However, another problem happened. there is no motion input from game to simtools v3
  8. yobuddy
    51,539Coins
    The first thing to check is the interface setup for SimTools v3. Please click "Test Settings" for the interface you setup, does your simulator move as expected with the test sliders?
  9. William816
    48Coins
    problem solved after delete the game plugin and reinstall.
  10. William816
    48Coins
    is there introduction about how to estiablish the VR connection with quest 3. I tried the epic roller yesterday, ant it seems simtools not support vr. thansk.
  11. yobuddy
    51,539Coins
    If the game is running on the headset itself, you will need the console version of the the plugin here.
    https://simtools.us/plugin/?varname=221&color=0e97dd
    With the game running on the headset, go into the games settings, and enable telemetry with the ip address of the computer running SimTools, and the port set to 4123. Then simply double click the play button on the console plugin in SimTools and you should get data.
    Please let me know how it goes.
