Just started SMC3 Utils but motor keeps spinning
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by floridianer, Oct 18, 2024.
  1. floridianer
    floridianer New Member
    47Coins
    just finished my solderings of my 2DOF Flight Rig.
    When activating the motor, it begins to spin but i am not able to stop and control the motor.
    Only reacts to "Fpwm" but nothing else.
    Can you please give me a hint to solve the problem?
    Thx
    152,706Coins
    +11,092 / 56 / -2
    What control board and pots are being used?
  3. floridianer
    47Coins
    152,706Coins
    +11,092 / 56 / -2
    At rest, so the rig in its default position, the pot and hence the pot line should be centered in the SMC3 graph.
    Again what are you using for pots and how are they connected to the motors?
    You should be able to first disconnect power to the motors, then rotate the pot by hand until it is centered, then reattached the pot to the motor and reconnect power to the motors.
    As an aside your SMC3 setting seem a bit all over the place, how did you come to determine them?
  5. floridianer
    47Coins
    I basically chose the settings randomly. I haven't had any specifications yet when it comes to the settings.
  6. floridianer
    47Coins
    I just watched a video from Dave on YT where he tries to explain how to calibrate the pot. now i come closer to it but still don't understand, why it still spins below 35kHz. at 35 the motor stands still...
    152,706Coins
    +11,092 / 56 / -2
    As I mentioned your SM3 settings look odd, so please set Fpwm to 25 then follow the SMC3 setup steps below, and if something does not work as expected please let us know what step that is at:
    8. Set Kp to about 400
  8. Slawko
    Slawko New Member
    NI
    34Coins
    did u try to swap motor cables (+ & -) it cold be also bad ratio motor to sensor are they 360deg sensors??
  9. floridianer
    47Coins
    thank you both for your advice and I followed every point.
    I made the settings as you told me.
    However, the motor still turns as soon as I set it to 30 or 25 kHz. Even if I set the other values as you advised, it has no effect on the motor. Could it be the pots?
    As far as I know, these are 360° sensors. And no, I haven't mixed up +/- yet.
    What do you mean by the motor to sensor ratio?
    152,706Coins
    +11,092 / 56 / -2
    What are your current settings, please post a picture, and also advise at what point in the setup instructions failed.
  11. floridianer
    47Coins
    your setup instructions failed at 7)
    when I start the motor and it shouldn't be turning, as you say.
    Unfortunately, it turns the whole time at 25kHz.
    The same goes for 30Khz, but it doesn't turn at 35kHz.
    152,706Coins
    +11,092 / 56 / -2
    If the rig is at its centered position the pot line should be over the middle blue line, are you sure the pots are centered properly.
    The other possibility is faulty IBT2s. What voltage PSUs and motors are you using?
  13. floridianer
    47Coins
    i think that the pots are centered porperly. i just ordered two new IBT's. They will arrive tomorrow.
    152,706Coins
    +11,092 / 56 / -2
    Other members have reported issues running IBT2s at 24v, dropping a couple of volts seems to be more reliable.
