Showroom DIY 2 DOF + traction loss + belt tensioner + Active pedal (Racecab style)
Discussion in 'DIY Motion Simulator Projects' started by hoyang, Mar 11, 2018.
  1. hoyang
    hoyang handyman
    Bricoleur
    1,343Coins
    new project in progress:
    active pedal.
  2. John Snell
    John Snell Member
    192Coins
    The pedal looks incredible. Looking forward to learning how if feels once you have it running
  3. hoyang
    hoyang handyman
    Bricoleur
    1,343Coins
  4. hoyang
    hoyang handyman
    Bricoleur
    1,343Coins
    Hello everyone, I will need your opinion on how my seat works. my seat equipped with 2 different systems to try to obtain the most realistic effect possible. The belt tensioner is equipped with two motors each with a force of 2.4Nm to obtain a sway and surge effect. The seat is equipped with two subwoofers (one in the back and one under the seat) and 2 speakers (7.1 rear game sounds) to create a constant vibration of RPMs and road vibrations. The feeling for me is not bad but I wonder about the effect of the belt on the body during the effects. on the surge when I brake, should the belt pin me to the bottom of the seat or release me towards the steering wheel? . on the sway the belt should pull me towards the inside of the turn or towards the outside?. thank you.
  5. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,025Coins
    3DOF, DC motor, Arduino, 6DOF
    Try the belt tensioner one way, then play a bit. Reverse it and play again. You'll see which one you prefer. I never had a belt tensioner, but I would make it pull on me on break. Like a pushing plate in you seat would push on you at acceleration.
  6. John Snell
    John Snell Member
    192Coins
    I think it should pull you into the back of the seat to give the feeling that you being thrown forwards into the seatbelt
    I'd say the outside
  7. hoyang
    hoyang handyman
    Bricoleur
    1,343Coins
    active pedal V2: replacement of the magnetic encoder with a mechanical encoder and modification of the parts for better inclination.
  8. hoyang
    hoyang handyman
    Bricoleur
    1,343Coins
    sorry for the noise, I placed it on a metal shelf.
  9. hoyang
    hoyang handyman
    Bricoleur
    1,343Coins
  10. hoyang
    hoyang handyman
    Bricoleur
    1,343Coins
    ABS feel test for active pedal
  11. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,025Coins
    You are a pretty good driver.
  12. hoyang
    hoyang handyman
    Bricoleur
    1,343Coins
    new rail under test
  13. evolaco
    evolaco Member
    Spain
    694Coins
    Hi, could you explain more about the brake pedal? What software do you use? Do the games have some kind of brake telemetry or is it all done with external software?
    And mechanically is it just a motor with a spindle and a load cell?
    I would appreciate more information and if there is a thread about this in this forum or others.
  14. Misanthrop
    Misanthrop Active Member
    826Coins
    There is an active Discord with all the information, just google DIY FFB Pedal.
  15. hoyang
    hoyang handyman
    Bricoleur
    1,343Coins
    I invite you to join the discord for more information
    french :https://discord.gg/nhbR3vYd
    English: https://discord.gg/zTfQaxpAUz
  16. hoyang
    hoyang handyman
    Bricoleur
    1,343Coins
  17. hoyang
    hoyang handyman
    Bricoleur
    1,343Coins
    Update: Upgraded to a triple screen setup with two video projectors and a 40-inch screen. The result is more than satisfactory.
