Lesson Twist Handlebar, Accelerator, Brake, Clutch : GP-Bikes Project
Discussion in 'DIY Motion Simulator Projects' started by AndresAmaral, Feb 6, 2024.
  1. AndresAmaral
    AndresAmaral Andres Amaral
    Uruguay
    42Coins
    I am making a 2dof simulator for GP-Bikes
    I share the abances with arduino
    using the following components:
    x1: Arduino Pro Micro
    x4: 1K Potentiometers
  2. AndresAmaral
    Uruguay
    42Coins
    The chassis I will use is from a Yumbo R8 motorcycle.
    The handlebar is an adaptation using a front fork from a Beta RK6 motocross.
  3. AndresAmaral
    Uruguay
    42Coins
    I leave a small video tutorial
    Required program: Arduino 1.8.16 - Download: https://downloads.arduino.cc/arduino-1.8.16-windows.exe
    Components:
    An Arduino Pro Micro Board
    4 1K potentiometers
    Video-tutorial MP4: https://archive.org/download/control-sim/ArduinoControlSim.mp4
    I previously left a wiring diagram and code and Joystick library for Arduino.
    After loading the arduino .io code you must calibrate how a joystick is calibrated - Calibrate the steering (handlebar), accelerator, brake and clutch. And now you can test the potentiometers in a game, I created it for GP-Bikes. It also works for car simulators.
  4. AndresAmaral
    Uruguay
    42Coins
    I will try 24v marcopolo bus wiper motors
  5. Sebastian Jauregui
    Sebastian Jauregui New Member
    6Coins
    Hello, have you thought about adapting an accelerator with a hall sensor?
    I tried to download the video but it is no longer available.
  6. Chris_Beeves
    2,196Coins
    Pretty much any of the hall sensor throttles work just fine. You do get what you pay for though when it comes to reliability and linearity.
  7. AndresAmaral
    Uruguay
    42Coins
  8. AndresAmaral
    Uruguay
    42Coins
    The archive.org server was down for a while, you can check it now.
  9. AndresAmaral
    Uruguay
    42Coins
    New design
