Resolved Why my motor is not moving?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Jango, Nov 2, 2024.
  1. Jango
    Jango Member
    Mauritius
    370Coins
    2DOF, DC motor
    Hi everyone,
    I am struggling with motor 1, and it is not moving.
    So here's a summary of the situation:
    rig: 2DOF (Motor 1 and 2)
    motor: Wheelchair motor 24v
    Motor 2 works fine, but motor 1:
    - Makes crackling noises when the potentiometer line is brought near the blue line.
    - Then it either moves in a jerky manner or does not move at all.
    - I swapped IBT motor controllers, same issue - both IBTs work fine with motor 2.
    - I reversed the connections, but i have spikes and the motor cuts off.
    I am posting a few pictures here, let me know what you think.
    I followed the tutorial, by setting everything to zero and gradually increasing the values, but when i increase pwmax, nothing happens - but when i put on motion, then it makes the jerky movements.
    The motor seems ok, it does move, but the movement is quite erratic. i'm not sure what is happening.
    Thanks for your help.
      69.9 KB
      112
      81 KB
      113
      63.8 KB
      115
      73.9 KB
      237
    152,189Coins
    +11,064 / 56 / -2
    The posted settings seem all over the place, for some the pot does not seem centered and for others, such as this, the clip and max limits are not set to 255 for testing, as per the SC3 instructions:
    Please follow the SMC3 setup steps and post a picture:
    8. Set Kp to about 400
  3. Jango
    Jango Member
    Mauritius
    370Coins
    2DOF, DC motor
    Thanks Noorbeast, i didn't have proper sleep over it. I'll follow the instruction closely and also doublecheck the wiring.
  4. Jango
    Jango Member
    Mauritius
    370Coins
    2DOF, DC motor
    Did some more tests. Still not moving.
    The Green line was moved by turning the POT. <-- So pot seems to be working fine.
    All parameters set to zero and clip limits to 255.
    For the above setup, only wiring to motor 1 and electricals were connected.
    When pwmax is increased, there is no movement.
    I'll check:
    - the motor - will connect it directly to the power supply to see if it moves.
    - Then the IBT
    - Finally the arduino and electrical connections.
    Will post the results here.
  5. Jango
    Jango Member
    Mauritius
    370Coins
    2DOF, DC motor
    The motor works fine when connected directly to 24v power.
    It looks like it is either the IBT, Arduino wiring.
    I'll check a bit later.
  6. Jango
    Jango Member
    Mauritius
    370Coins
    2DOF, DC motor
    Ok, some further tests:
    - Swapped IBTs, and they both work fine.
    - Now it looks like there was loose or faulty wiring to begin with.
    I noticed static noise on the motor at first (during the first test) - this can be a consequence of loose wiring.
    So, now the final test is to connect both motors and run them (after checking securing all wires) - then i'll solder everything up.
    152,189Coins
    +11,064 / 56 / -2
    Glad you got that sorted.
    Keep in mind other members have reported some issues running IBT2s at 24v, dropping a couple of volts seems to help with IBT2 longevity.
  8. Jango
    Jango Member
    Mauritius
    370Coins
    2DOF, DC motor
    Thanks a lot Noorbeast, the moral support on the forum was crucial. I nearly gave up at 1am.
    I used jumper cables to connect the pins of the IBT, i guess i'll need to solder them.
    And yes, i have now lowered my voltage to 18.5v, plus have a cooling fan.
    Hope this thread will be useful to others also:
    - don't give up
    - the documentation is very good, youtube is not always right
    - troubleshoot 1 thing at a time and swapping to eliminate possible causes.
    All the best :)
    • Optimistic Optimistic x 1
