Question How is the zero position set in the 2dof simulator?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Miszor, Nov 3, 2024.
  1. Miszor
    Miszor New Member
    100Coins
    Hello everyone, I'm planning to build my first 2dof motion simulator. I don't understand one thing: how the "0" position, i.e. horizontal, is set. I know that this can be set in the hardware by selecting the appropriate length of the motor arm and upper frame connector. The problem is that I don't understand how the program knows that this position is zero. Is this setting up somewhere? After turning on the motion rig again, how is the program supposed to know how to set the motors so that the platform is horizontal? I know my question may be stupid, but I really don't understand it, please explain.
    153,914Coins
    +11,154 / 57 / -2
    On the mechanical side the pot or Hall sensor is centered and attached to the neutral positioned lever, the pot or Hall sensor then gives positional feedback either side of that.
    How motioned is then tuned is on the software side, the base parameters via the software fore the control hardware and the motion software then is refined for the actual motion profile.
  3. Miszor
    Miszor New Member
    100Coins
    How is the Hall sensor centered mechanically? After powering up, the sensor recognizes the position it is in as "0"?
    153,914Coins
    +11,154 / 57 / -2
    No, like a pot a Hall Sensor needs to be positioned to zero, often control software like SMC3 or JRKs have a visual graph, which makes it really simple to do.
  5. Miszor
    Miszor New Member
    100Coins
    So before I start testing the motors in SMC3, I need to find the zero position of the Hall sensors? As I understand it, I can also use SMC3 software for this? Do you have any guide on how to do this? I have read many threads but I have never found anyone describing this stage in detail.
    153,914Coins
    +11,154 / 57 / -2
    Disconnect power to the motors, make sure they are in their centered position.
    Temporarily disconnect the coupler from the pot or Hall Sensor.
    Run the Windows SMC3 Utility software and turn the shaft of the pot or Hall sensor until the green line is centered on the graph.
    Reattach the pot to the motor in that position.
    Then follow the SMC3 setup steps: https://www.xsimulator.net/communit...3dof-motor-driver-and-windows-utilities.4957/
  7. Miszor
    Miszor New Member
    100Coins
    I understand that the centered position of the motors is the one I want to achieve to achieve the "0" state of the upper frame?
    153,914Coins
    +11,154 / 57 / -2
    Correct, though it depends on the design as to how the levers are set to their default angle relative to the top frame in its level position. For example a shoulder mount design has a default lever angle that is not zero.
  9. Miszor
    Miszor New Member
    100Coins
    Everything is clear now. Thank you for your help :)
