need help with DCS plugin and new Axis Force
Discussion in 'Digital Combat Simulators (DCS)' started by rocketfire302, Sep 27, 2024.
  1. rocketfire302
    rocketfire302 Member
    122Coins
    SCN5, SimAxe
    Hi
    i am working on a sim rig that uses g-seat and g-belt. what i want to do is force the g-belt shoulders to pull on you if the jet is inverted. however once the jet is upright the behavior is opposite and must work as normally setup in the axis controls.
    I know how to modify the Lua file to detect inverted etc, but i don't know how to create a new force that is not used by the others.
    let me explain further, - yes i can detect inverted and just manipulate roll, pitch, heave values etc in the lua file, but then that will mess up these forces for the other axis. I just want a force that i can link to the axis and control independently when inverted.
    What i noticed is the there are "not used" forces in the drop-down menu on Simtools DCS plugin.
    i also noticed in the lua there are outputs that don't match any of the dropdowns.
    socket.try(c:send(string.format("%f; %f; %f; %f; %f; %f; %f; %f; %f; %f; %f; %f; %d; \n", slot_roll, slot_pitch, slot_yaw, slot_heave, slot_sway, slot_surge, slot_roll_rate, slot_pitch_rate, slot_yaw_rate, slot_aoa, slot_ias, slot_rpm, slot_onground)))
    i do not see any parameter that is for this "un-used" force, unless these values above correspond to the them.
    is it possible to link a "not used" force to a socket output so that i can drive the belt using it.
  2. BrassEm
    BrassEm G-Seat + SFX100 Builder Gold Contributor
    NE of YMML
    1,102Coins
    DC motor, AC motor, 4DOF
    Were able to work out how to interface the belt drive to g heave force?
